Put the Continental DWS06+ on my ‘24 Nismo
iztrumental
Virginia
2024 Nissan Z Nismo
Finally replaced the stock Dunlop’s with the Continental ExtremeContact DWS06+ and then took it to Firestone for their lifetime alignment. After I posted a picture of the alignment done in a Discord, a more experienced in cars friend of mine pointed out how the rear wasn’t changed and how the rear toe was “off”. I mentioned this to the person in Firestone and he said they scan the car and follow the Nissan specs. He also said it’s within “green” but my friend said it’s not a good alignment. I couldn’t get a copy of the mentioned specs after the job was done but next time I will ask them for a copy. Does anyone here have a copy? I didn’t have much luck with a quick google search.
Some pics of the tire below along with a pic of the alignment.
Having a bit of toe in out back helps with straight line stability and acceleration. No biggie at all. You are showing .22 and .14 of a degree. It’s not a lot by any means. In the front, they got you more precise toe in but closer to 0 which is good. For a track car it’s normal to even run a tiny bit of toe out in the front. (Helps with initial turn in) but close to 0 is good. As long as one side isn’t way out of wack you should not have any bad wear issues. If you’re an aggressive driver, if you get some adjustable front upper arms, you can dial some more negative camber in and help with corner bite and stability. Otherwise it looks like you’re golden to me ??‍♂. Hope this is helpful.
iztrumental
iztrumental
Virginia
2024 Nissan Z Nismo
Thank you so much! That makes me feel better. It actually felt fine driving but I’ll find out more when I hit my fave backroad this weekend.
msco123
Louisiana
2024 Z Nismo, 2024 Z Performance, 2025 GMC Canyon Denali, 2024 Lexus RC350
I was thinking of changing my back tires to help with road noise. Did you notice any change in road noise?
Papa G Z
Gary
Colorado
2023 Z performance manual, Rosewood 8000 miles. 2008 Saturn Sky redline
Retired 2025
Thanks for sharing your new tire choice. I have a 24 performance rosewood. About 6000 miles on it. Picked up April 2023.
My wife has a 2008 Saturn sky redline with 16000 miles and 10,000 when I bought it with original tires. I put those same continental brand on the Saturn and they are fantastic for traction and it corners like a go-cart. Only downside is it’s harder to spin the tires…but it will! It’s a automatic
I’m thinking of the same swap maybe next year. How many miles did you have on the Dunlop tires and were they warn to a need if changing or just a desire for a different tire. Curious how many miles folks are getting to where tread prompts a change versus trying a different brand. My Z is a 6 speed
also looking at the borla street cat-back. Any comments on that vs other without hi-jacking the thread? Don’t want too loud as I’m too old for that LOL!
iztrumental
iztrumental
Virginia
2024 Nissan Z Nismo
I have over 6K miles on the Dunlop and the installer told me they’re still good for use and have about half of thread life left. I wanted new all weather tires because I’ve had a few sketchy moments in the rain because I’m one of the few that don’t mind driving the car in the rain ?.
Thanks for sharing your experience with the tire. I’ve had so many others share their love for them!
Z-ski
Norfolk, Va
2024 Z, 2020 Equinox
I'm curious if you felt like you lost any traction going from the summer tires to the all-seasons.
I've been looking at both the DWS 06 Plus and the Pirelli P Zero AS Plus 3 as options based on this report and my positive experience with the Potenza Sport AS on my previous Mustang.
I want to put all season tires on, but I'm a bit nervous as I suppose the car was designed around summer tires.
Papa G Z
Gary
Colorado
Retired 2025
Sorry 2023 performance not 24
KnightRiderz
Adam
Maryland
Military
Could you please post more pics of them on your car. I’m about to pull the trigger on these and would like to see your setup. Thank you
iztrumental
iztrumental
Virginia
2024 Nissan Z Nismo
Oh man I don’t have the knowledge or expertise about using different size tires for front but I believe there’s some info in these forums about it.
