New Work Meisters Ordered
BeShizz
BeShizz
Bee
Santa Clarita
2025 Nissan Z
They are in west Covina so that should be relatively close to you as well (1.5 hrs per google maps)
Got the car aligned and adjusted negative camber. I'd say it closed up that gap a lot better. Probably could have gone a bit wider on wheels initially, but I think this is as far as I would want the wheels to the fender.
BeShizz
BeShizz
Bee
Santa Clarita
2025 Nissan Z
We only limit ourselves
TE37 Ultra
20x11, +15, 275/30
20x12, +20, 315/25
TE37 Ultra
20x11, +15, 275/30
20x12, +20, 315/25
Looks good, I was stuck on how much I wanted the wheels to poke out of fenders. But preferences I guess. I like close to flush with fenders and not so much poking out.
Does yours hit wheel well or fender if you hit a bigger bump or steeper driveways? Unless your on bags.
When I had those wheels, i was on straight Aragosta Type S coilovers. No rubbing in rear. Fronts, had to relocate a front bumper tab inward.
rears are rolled from the factory
Fronts are pulled a bit
now I have Stanceparts air cups on top of the coilovers, all 4 corners. Air cups operate as normal coilovers until activated, then provide 1-2 inches of lift as needed. When deactivated they do nothing.
These do not affect fitment as they dont change static alignment. Got them to save my front bumper/lip
Now running three piece wheels for more aggressive fitment since one piece wheel sizing is more limited
19x10, -1
19x11, -6
Bumflik
Issac
illadel
Bus Operator
19x10, -1
19x11, -6
I knew you were knowledgeable and have experienced with fitment. Flawless!!!
BeShizz
BeShizz
Bee
Santa Clarita
2025 Nissan Z
19x10, -1
19x11, -6
Thanks for the information! Looks good. Hopefully your liking the 3 piece fitment.
HWill
HW
Arizona
2025 Nissan Z Performance
I think this looks good. Wider tire and you might have to add some camber unless you are running a super stiff in the rear. How much camber did you set it too in the rear?
IMO if you are rolling or pulling fenders then it is not a perfect fitment.
But Id say OptionZero you made it look perfect for your setup.
SleepyD7
Gainesville Florida
2024 Manual Nissan Z Performance
Audio Video Integration
Head up bro. That setup is straight baller. The fitment is near perfect. Size and stance is 👌 IMO. That color combo on dem Meisters. 👌👌 I have seen 100’s of RZ34’s on wheels here and yours is my favorite.
Will you be at JCCS this year? Like to check out your fitment and specs, great setup!
Japanese Classic Car Show in Long Beach CA, huge show and vendors, google it.
