Factory Installed Dashcam Instructions
JChandler82
Josh
WV
Director of Endpoint & Infrastructure Support
Hey everyone!
I wanted to share a quick guide for setting up the factory-installed dashcam in the Z. From what I can tell, most models didn’t come with it, and the setup info is practically nonexistent. My dealer had no clue, and I couldn’t find clear instructions anywhere online.
I’ve worked in IT for a long time, so struggling with something this simple was… let’s just say frustrating, to put it mildly. 😂 When I first got the car, I sat in my driveway for almost an hour trying to connect—only to fail, quite successfully. After months of driving around listening to it ding over every bump, I finally decided to give it another try. And wouldn’t you know it—it connected on the very first attempt! Same phone, same app, same setup—just a different location. I think that was the key.
IMPORTANT TIP:
When you connect to the camera’s Wi-Fi, your phone will notice there’s no internet connection (which makes sense). This was probably what tripped me up the first time.
Here’s what I think happened: after I connected to the camera’s Wi-Fi but before opening the mDrive app, my phone automatically switched back to my home Wi-Fi in the background—causing the app to fail the connection. I even tried deleting my home Wi-Fi from my phone at one point, but still had no luck.
The second time around, I was in my work parking garage, with Android Auto unplugged and no other Wi-Fi networks around—and it connected instantly. So keep that in mind when you try these steps.
Setup Steps:
  1. Install the mDriveRecorder app from your app store.
  2. Start the car and connect to the camera’s Wi-Fi. In your Wi-Fi list, look for something like MDRIVE***********
    PASSWORD: 0123456789
    • Your phone will probably warn you there’s no internet—just confirm you want to stay connected.
  3. Open the mDriveRecorder app and acknowledge the warning.
  4. Tap “Connect to Drive Recorder.”
  5. From there, you can access Live View, Video List, and Drive Recorder Settings.
I know the camera isn’t exactly top-tier—but it’s already installed, tucked away neatly, and does what it’s supposed to do. So why not roll with it?
Hopefully this saves someone else a little time (and frustration)!
EarlsFat
Jim
2024 Z Performance, 1970 Camaro RS, 1953 Ford F100
CPA
ohohohohohoooooooooooh!!!
So I was going to ask dealer if they can add one to my 24 Performance when I have it in there next week. Questions:
1. Is only forward facing, or does it record rear view as well?
2. Are the videos easy to access?
3. Is the picture quality as lousy as the back up cam?
ED-NWI-Heritage
Ed
Schererville, IN
2024 Nissan Z Heritage
Accountant
Could you include a picture of the dashcam? I bought a used 2024 Heritage, and I have been unsuccessful at getting a copy of the original factory window sticker to know what is or is not on the car. The Nissan Owner's web site has a "My Garage" page, which has an option to display the window sticker, but it errors and I spent hours on the phone with folks from Nissan only to be told to ask my dealer to get the sticker. Super frustrating, the manufacture can't provide me the window sticker. I read someplace that all the Heritages came with the same options in either MT or AT. I doubt my Z has a dashcam, but I thought I'd ask.
abdullah
rz34
99628818a
z400
[اقتباس="JChandler82، المنشور: 140869، العضو: 4016"]
مرحبا بالجميع!
أردتُ أن أشارككم دليلاً سريعاً لتركيب كاميرا لوحة القيادة المُركّبة من المصنع في سيارة Z. على حد علمي، لم تكن مُرفقة مع معظم الطرازات، ومعلومات التركيب شبه معدومة. لم يكن لدى وكيلي أي فكرة، ولم أجد أي تعليمات واضحة على الإنترنت.
لقد عملت في مجال تكنولوجيا المعلومات لفترة طويلة، لذا كان التعامل مع أمر بسيط كهذا... مُحبطًا للغاية ، على أقل تقدير. عندما حصلت على السيارة لأول مرة، جلست في ممر سيارتي لمدة ساعة تقريبًا أحاول الاتصال، لكني فشلت، وبنجاح باهر. بعد شهور من القيادة والاستماع إلى صوتها وهي تتعثر ، قررت أخيرًا تجربتها مرة أخرى. وأليس كذلك؟ لقد اتصلت من المحاولة الأولى! نفس الهاتف، نفس التطبيق، نفس الإعدادات - فقط في موقع مختلف. أعتقد أن هذا كان سر النجاح.😂
نصيحة مهمة:
عند الاتصال بشبكة واي فاي الخاصة بالكاميرا، سيلاحظ هاتفك انقطاع الاتصال بالإنترنت (وهذا أمر منطقي). ربما كان هذا ما أربكني في المرة الأولى.
أعتقد أن ما حدث هو التالي: بعد اتصالي بشبكة واي فاي الكاميرا، وقبل فتح تطبيق mDrive، عاد هاتفي تلقائيًا إلى شبكة واي فاي المنزلية في الخلفية، مما تسبب في فشل التطبيق في الاتصال. حتى أنني حاولت حذف شبكة واي فاي المنزلية من هاتفي، ولكن دون جدوى.
في المرة الثانية، كنتُ في موقف سيارات عملي، مع فصل تطبيق Android Auto وعدم وجود شبكات Wi-Fi أخرى، واتصلتُ فورًا. لذا تذكّر ذلك عند تجربة هذه الخطوات.
خطوات الإعداد:
  1. قم بتثبيت تطبيق mDriveRecorder من متجر التطبيقات لديك.
  2. شغّل السيارة واتصل بشبكة واي فاي الكاميرا. في قائمة واي فاي، ابحث عن شيء مثل MDRIVE ***********
    كلمة المرور: 0123456789
    • من المحتمل أن يحذرك هاتفك من عدم وجود إنترنت - فقط أكد أنك تريد البقاء متصلاً.
  3. افتح تطبيق mDriveRecorder وأقر بالتحذير.
  4. اضغط على "الاتصال بمسجل القيادة".
  5. من هناك، يمكنك الوصول إلى Live View و Video List و Drive Recorder Settings (إعدادات مسجل محرك الأقراص).
أعلم أن الكاميرا ليست من الطراز الأول، لكنها مُركّبة ومُخبأة بعناية، وتؤدي وظيفتها على أكمل وجه. فلماذا لا تُضيّعها؟
نأمل أن يوفر هذا لشخص آخر القليل من الوقت (والإحباط)!
[/يقتبس]
أين الكاميرا؟
JChandler82
JChandler82
Josh
WV
1. It has forward facing and rear facing (in cabin) cameras with audio.
2. Yes, very easy with the app. Or you can pull the SD card and load it up on your phone / computer.
3. Picture quality is average. Not great, but not terrible either.
JChandler82
JChandler82
Josh
WV
Here you go!
Hubert
Hubert
Hubert
Z33 NISMO R-tune, RZ34 NISMO
I also had this installed when I bought the car and just like your experience, I had to figure everything out on my own.
Avoid it and go with a third party, if you want a dashcam.
We're talking about an optional Nissan Dashcam product & not the built in front facing camera. Correct? I was able to get a display from the existing front facing camera (I don't have a 'dashcam')...and it made me wonder if someone could create an app that recorded from it?
On another note… I wish there weren't so many WiFi networks in the car. For me there's the internet 'MY-Z Hotspot' & WiFi CarPlay and also a Vgate WiFi ODBC dongle that lets me monitor all the extra sensors (Cat temps, turbo A/B speeds, MAP pressure, Cold Intake temp, etc). I just ordered a bluetooth 4 ODBC dongle and that may let me display the extra sensor data within (WiFi) CarPlay. We'll see.🤓
There's a separate thread about ODBC sensor monitoring. A search for dongle should find it.
/rant mode = on/
The whole problem is that the iPhone (and likely any device) can only connect to one WiFi at a time. So if you're in your own driveway and your home network is set to auto-join, then your Carplay or Dashcam WiFi network won't work without manually connecting them. The phone can just switch back to the home WiFi, which is exactly what the OP described. I wish it wasn't so complicated. Wired CarPlay seems easier.
/rant mode = off/
msco123
Louisiana
2024 Z Nismo, 2024 Z Performance, 2025 GMC Canyon Denali, 2024 Lexus RC350
I am trying to install this camera and while I have power to unit, it will not turn on. Any suggestions?
