- Thread starter
- #16
easy - did it all by myself. after removing all the clips and bolts from the top and bottom shrouds, i removed the front 2 bolts behind the fender liner, two wire harness clips and pulled the clips loose under each headlight in that orderHow hard was it to remove the bumper? 2 person job?
i pulled one clip on the fender liner to help get to the fender bolts. then pulled the passenger side bumper from the headlights. then i was able to access the wire harness clips. then pulled the driver side loose from the headlights. then pulled the bumper off.
