CZP Heat Exchanger Install
How hard was it to remove the bumper? 2 person job?
easy - did it all by myself. after removing all the clips and bolts from the top and bottom shrouds, i removed the front 2 bolts behind the fender liner, two wire harness clips and pulled the clips loose under each headlight in that order
i pulled one clip on the fender liner to help get to the fender bolts. then pulled the passenger side bumper from the headlights. then i was able to access the wire harness clips. then pulled the driver side loose from the headlights. then pulled the bumper off.
el mágico
Anyone install an upgraded coolant pump with the controller? From my understanding, this really uses the heatX to its full potential.
I just did the HX.
I wonder if an ecutek tuner could do the logic upgrade instead of having a piggyback controller?
el mágico
I just did the HX.
Good question. I'm in the same boat as you. I just have the czp heatX.
Kicking around the idea of going A2A. Either Z1 or Greddy. I guess we'll see.
Well well - looks like ecutek can control the stock pump - may not need to change the pump and controller?
1. Activating and Driving the Pump (System Bleeding)
When installing an upgraded aftermarket heat exchanger (such as AMS, Z1, or Racebox), trapping air in the lines is highly common and leads to inconsistent performance. EcuTek has a built-in function to manually pulse the pumps: [1, 2, 3, 4]
    • Connect your EcuTek Bluetooth OBD-II Interface to your car.
    • Open the ECU Connect mobile app and switch the car's ignition to the ON or accessory position (engine does not need to be running).
    • Navigate to My Car → Custom Inputs.
    • Look for the input parameter labeled "Drive Pump Max" or "Pump Time".
    • Toggle this option or increase the percentage to force-command the electric auxiliary cooling pumps to cycle continuously.
    • With the pumps actively driving, open the bleed valve on your top tank or heat exchanger to cycle the trapped air pockets out until the pump runs smoothly. [1, 2, 3, 4, 5, 6, 7]
2. Tuning Custom Maps (ProECU Software Side)
If you are a tuner configuring the ROM file via the desktop ProECU software, or working with a remote master tuner: [1]
    • RaceROM Custom Features: EcuTek maps allow custom definition tables that tie the intercooler water pump duty cycle to specific engine variables.
    • Target Mapping: The pump's PWM (Pulse Width Modulation) duty cycle can be scaled based on Manifold Air Temperature (MAT), Engine RPM, or Target Boost.
    • Full-Time Flow: Many performance tuners map the pump to ramp up to 100% duty cycle much sooner than the OEM Nissan logic to prevent "heat soak" before a heavy pull or drag run.
3. Adjusting Pump Speed via ECU Connect App
If your master tuner has mapped the feature into your active EcuTek RaceROM file, you can manually adjust your heat exchanger pump settings directly from your smartphone: [1]
    • In the ECU Connect app, go to Custom Inputs.
    • Select your mapped pump slider.
    • You can toggle or step-adjust the duty cycle output (e.g., locking it to 40%, 60%, 80%, or 100%) depending on whether you are street driving or staging at a track. [1]
el mágico
Nice find. I wonder if the stock pump can handle the additional volume, reliably. Or, second option, install the aftermarket pump and let ecutek do it's thing.
Looks like you can run it at 100% full time but not sure how much that will help. i wonder if any of the tuners has or can do the programming?
Cujo2811
Joe
2024 Nissan Z Performance 6MT
I read you can do the same thing with the Z1 diagnostic tool if you don't have EcuTek.
