dogunbound
- First Name
- Shane
- Joined
- Mar 9, 2024
- Threads
- 25
- Messages
- 131
- Reaction score
- 96
- Location
- Houston, TX
- Car(s)
- Nissan Z
- Occupation
- Software Engineer
- Thread starter
- #1
After having a scary track day (110MPH slide off into the grass), I am starting to want a much stiffer set of suspension. Even my instructor on board said the car probably would not have stepped out on me with a tighter setup.
There are SO many opinions on this, that at the end of the day, I know I will just have to pick one and hope I like it. Regardless, there are a few questions I have.
- What are the stock spring rates in the performance model?
- Looks like this is still unanswered
https://www.nissanzclub.com/forum/threads/oem-nismo-2024-spring-rates.2635/
- How much will I need to adjust the spring rate measurement from bucket springs to true coilover springs for a comparable measurement?
- Are any of these options unreliable? I am looking for something that should perform exceptionally well for 5 years would be the goal. Failures after 8 years would be "expected". The KWs are my upper limit tbh. I do not want to spend 7k for a split oil reservoir suspension setup. If you have other recommendations, please let me know!
- Billstien B16 https://www.rockauto.com/en/moreinfo.php?pk=6609676&cc=3454543&pt=10922&jsn=709
- Fortune Auto 500/510 (Probably 500) https://martiniworks.com/products/s...rz34-separate-style-rear-500-series-coilovers
- BC racing DS https://martiniworks.com/products/s...es-coilover-22-nissan-400z-true-coilover-rear
- KW Variant 3 https://www.z1motorsports.com/nfs/kw/kw-2023-nissan-variant-coilover-kit-p-44950.html
- z1 coilovers https://www.z1motorsports.com/z1-pr...-nissan-pro-true-style-coilovers-p-43107.html
- What spring rate is known to not be dailiable by most people? As for the z1 coilovers, I see they are 16k front 8k rear. That seems quite aggressive, no? I personally do not care for how soft the stock suspension is. I used to drive an 03 camry with BC racing BR coilovers (6k front 3k rear), and that was incredibly comfortable even at the tighter rebound/compression setting. The Z's suspension was a legitimate downgrade IMHO.
- Are swift springs worth the hype?
- If you have bought custom suspension, what spring rates are you running? Additionally, are you tracking your vehicle?
