Clutch pedal assist spring.
Texas RZ34
Jaime
2024 Nissan Z performance manual
Oil and Gas
The best 9 dollars I've spent for my 24 performance. The clutch pedal feel and clutch travel is instantly better.The gear changes feel so much more smooth and quick. Don't miss this easy mod if you have a 6 speed.
RHE2026
2026 Heritage Edition
I noticed even a new 26 Z to me my clutch pedal feals a bit soft. I will look into that spring for sure. Thx
Texas RZ34
Texas RZ34
Jaime
Oil and Gas
Just trying to help fellow RZ34 owners. Sorry I didn't mention I have a 24 performance.
Lyosuke3
Leo
2023 Nissan Z M/T Performance
So how does this spring feel? Is it softer or stiffer? I just ordered it based on your recommendation. How is the shift from 1st to 2nd? Any improvement?
I would really like to purchase the RJM Clutch eventually, but it's out of budget right now.
Thanks for the posts - the RJM clutch pedal looks like a nice option….
Per ai, the spring is softer than oem making the clutch pedal heavier - some folks remove the spring completely…
Texas RZ34
Texas RZ34
Jaime
Oil and Gas
I feel like the clutch pedal is lighter with the new spring. Also the clutch travel seems way shorter but it's nice. It was too cheap not to try and you could always revert back if you don't like it.
Texas RZ34
Texas RZ34
Jaime
Oil and Gas
To me it feels softer. The shift from first to second feels faster due to the clutch pedal travel. But I still get the occasional grind feel every now and then. Getting out of first from a dead stop has improved. I don't feel like I'm riding the clutch to get out of first. Hope this helps!
Lyosuke3
Leo
Yeah, thanks for following up! Sounds like it make a significant different. I've seen alot of previous 350/370z owners say that the RZ34 clutch feels lighter. This is my 1st M/T, but I've driven other makes/models and the clutch feel more light and easier to engage. Plus the rough shift into 2nd gear felt odd.
I was reading up about it and found some youtubers talking about replacing the spring if you can't get the RJM Clutch Pedal. So I was thinking of doing that in the mean time when I found your post. Hope the shipping doesn't take too long!
aurora rz34
Brock
Pennsylvania
2026 nisaan z heritage edtion
When you were installing the spring was there 2 springs cause when I took mine apart I only found 1 I think if there was a second one it shot off somewhere never to be found again but I’m not sure all the videos are for older generations.
Lyosuke3
Leo
I got mine in the mail, but haven't had a chance to install yet. I was planning to install it this weekend. I'll let you know how it goes! Did you reinstall it with just the 1 spring? Have you had any issues?
aurora rz34
Brock
Pennsylvania
I haven’t had any issues so far as far as I could find the little spring only pushes on the pedal at the very top of the swing when your not pressing on it I’m sure I’d be fine the only thing that I’m worried might happen is I go over a bump with cruise control on and it lets go of the cruise control button and disengages the cruise control.
aurora rz34
Brock
Pennsylvania
Also I the clutch is heavier with this new one it feels like it’s a shorter throw even though it isn’t I love it so far.
aurora rz34
Brock
Pennsylvania
Also if you could if there are 2 springs could you take measurements so I could find a replacement please and thank you.
Lyosuke3
Leo
If I see I'll let you know. Also, you can probably find it at the dealer. I can't imagine it being expensive.
aurora rz34
Brock
Pennsylvania
If what I could find on the matter is true it’s a part that’s not sold individually just as a whole pedal assembly
