Clutch pedal assist spring.
Lyosuke3
Leo
2023 Nissan Z M/T Performance
If what I could find on the matter is true it’s a part that’s not sold individually just as a whole pedal assembly
Oh wow, that's insane! I'm getting nervous about the replacement. Don't want to lose any parts!
aurora rz34
Brock
Pennsylvania
2026 nisaan z heritage edtion
Yeah just when it finally releases from the pedal just keep an eye on the top of it also the pin is very hard to get to slide out get a pair of channel locks and work the pedal back and forth it’ll come out and you’ll need the channel locks to press it back in too.
Lyosuke3
Leo
Hey Bro! Sorry for the delay! I finally swapped it and I'm loving it, the bite point feels a lot lower and my shift into 2nd gear is much smoother. There was no little spring! I was worried so I grabbed a big ziplock bag and cut an opening, wrapped it around so that nothing would fly out crazy. I'm 100% sure mine didn't have a little spring!
I think this made a huge improvement for me that I'm not even considering the RJM Clutch anymore. At least it's no longer a priority for me. Hopefully that gives you some peace of mind that your clutch is fine.
aurora rz34
Brock
Pennsylvania
Thank you so much I’m very much enjoying it as well it’s nice to know that I’m not missing anything and for all who read this before you purchase a RJM clutch pedal spend the 8-10$ on this spring first to see if it’s a good fix for you before spending much more money.
hohenheim
Martin
AR
2023 Nissan Z, 1990 300zx
The best 9 dollars I've spent for my 24 performance. The clutch pedal feel and clutch travel is instantly better.The gear changes feel so much more smooth and quick. Don't miss this easy mod if you have a 6 speed.
Do you have a link to this?
Lyosuke3
Leo
No problem! FYI, I thought it was going to ship from another country, but I got it within a week. I was super surprised with how fast I received it. Also, the install is pretty quick, like 15-20 min max. I kept putting it off thinking it would take a long time. Get some need nose pliers to remove a clip it has, then use an angled one to push the pin out and a pipe plier to pull it out. Then replace the spring in the whole setup, use the pipe plier to push the pin all the way back in. And then place the clip back on the end of the pin and secure it with the pipe plier. And don't forget that the bite point will be a bit lower when you go for your 1st drive.
hohenheim
Martin
AR
Good to know! Bad thing is its out of stock and the ones I found i didn't know whether or not they'd work and wanted one that someone had already verified.
