AWE Touring exhaust feedback wanted
Bluenoser
Justin
Nova Scotia
Lawyer & Fisherman
Well you guys are a bad influence for keeping an exhaust mod alive in my mind for the past month. Consequently, I just ordered the Track version which I will hopefully have in a few weeks time to install when my Z comes out of storage in the Spring. I can't wait!
ā€˜25 PRFM M/T Gun Metallic
A few final tweaks & adjustments!
Any concerns with a slightly larger rear sway bar with the AWE? I’m looking at the eibach @29mm vs Stillen @ 1ā€?
Fulshear, TX
VP
No concern with either; plenty of clearance. I did the Stillen swaybars to retain the stock bushings, but you can't go wrong with Eibach (I actually just ordered their springs tonight).
Fulshear, TX
VP
Eibach does retain the stock mounts, but replaces the bushings. Throughout the years, I've grown annoyed with squeaks & creaks from aftermarket bushings which is why I wanted to retain the factory bushings + mounts. Some are fine, and others even greased are still noisy.
Eibach brand bars specifically were dead silent on my Evo X while I could never get them completely noise-free on my C8 (low speed bumps & transitions).
Whiteline bars were fine on my Evo IX but total trash on the Evo X. Hotchkis bars on my C7 were the worst I ever experienced tenfold!
You guys know that the Stillen bars use stock bushings because of the added hollow thickness internally vs stock, so retains the stock bushings, not much thicker but noticeable w the avail adjustments. No squeaks so far.
Fulshear, TX
VP
Correct; same outer-diameter but thicker walls (smaller inner-diameter). Keeps the weight down too. Mine are perfect as well.
