Anyone changed wheel studs?
RZ34, or possibly Z34 (not sure how similar the hubs and other guts are under there).
Would like wheel spacers. Thinking 15 & 20. That will work, no scrub, on a bone-stock NISMO, right? Sounds like people are going 20 front, 25 rear on Perfs/Rays with no issues, and not trying to push the limit.
Also thinking 20mm extended studs and machining 5mm off for the fronts. A tad more as a package than bolt on spacers, but I dont want to shave the OEM front studs, and the setup is supposed to be an RCH more robust than bolt on (if you have to google that, congrats on not being an old fart like me). Also I don’t like the spacer nuts hidden and uncheckable with the wheels mounted. But if the studs aren’t readily-pop-outable and I have to unbolt stuff I may go with bolt on.
Donā€˜t want to remove two wheels just to look at the hubs, but if no one here chimes in I’ll do it and report back. I assume the majority of the crap under there is identical on all models.
Just popped in my head I’ll probably have to remove the brakes, or at least the rotors. Maybe wrong, but I think my Z33 Track rotors would wiggle off if you removed the brake pads. May not be able to do that with this one.
In other news: When I become president I’m imprisoning and confiscating the car of every Z owner that calls it a 400Z.
papozalsa
Jose
Virgina
Z 2024
Team Lead QA
I did changed the wheels stud in my 370Z. However, the length of the studs will match the spacer thickness so nothing will rub. I do not remember removing the brakes. I believe the shield has a hole that you will align with the stub you are removing.
toki
Tucson, AZ
I have done only the rears on my RZ34. It is the same procedure as the Z34 in back, at least.
D2M
Nismo Z, Veloster N, Ram 2500
I did them on my Nismo. The front hubs must be removed from the knuckle as there is no area to slip in an extended stud in from the back. The rear there is one spot where you can slip in and rotate the extended stud into place.
Loosen for space/access, or remove the hubs completely?
Bolted from the from back of the knuckle, no special tools or tricks needed?
D2M
You will have the whole brake system off anyway so its easier just to remove the hub completely, install the studs on the bench and reinstall the hub. Yes, its bolted in from the back, if I remember correctly its just 4, 17mm bolts. Dont forget to remove the ABS sensor first.
Would it help to knock the studs free, or at least partially, before removing the hub assy? Not sure how much force it takes to knock them out, and prefer not to be banging on 60 lbs of oddly shaped expensive gear on the bench.
D2M
Yes, knock them out first, they are not in that tight and you can get the oem studs out with the hub still on the car. The aftermarket studs are usually a bit tighter fit. I put a dab of WD40 on the knurled ends to help them press in using an impact and a stud installation tool, get one they are cheap and work great.
10-4. Looking as the Lisle installation tool.
@D2M
Are you on OEM wheels with the Ext Studs and what thickness are the spacers?
Im reading the OEM lugnuts will bottom out with Ext Studs on 15mm spacers. I tried searching for open ended OE style lugnuts. So far, nothing showing up.
D2M
@D2M
I was using 63mm overall length studs with 12mm or 15mm spacers depending on my alignment and tire size with oem wheels and lug nuts to get the perfect oem+ fitment . With a 63mm stud you can run 12mm-20mm spacers no problem.
HAVS
Lloyd
Georgia
2024 Z
Electrician
I just did my 2024. Took a minute to figure out how then the other side was like 30 minutes. I used z1 15 mm spacers and ARP extended studs. Definitely use the tool for them because it really is inexpensive. So what I learned is just pull the calipers off then pull the rotor off. In the front there is a small hole or notch towards the front of the car to slide them out and in. That backs were tricky. Find the deepest area and the longer bolts fit in but kinda at an angle not straight. Turn the hub and they slide right in. No hub removal was needed. I watched and read everything I could about this job and this is what actually worked.
Imperial
Southern California
I run the 61 mm Nismo Sports Long Hub Bolts with no spacers, only offset, just because I like the look and the added security of 100% thread engagement.
