Any thoughs on a plug-and-play tuning module for the Z Nismo?
staying_tuned
Kentucky
23’ Z Performance Manual
ECUTEK - i‘m pretty sure re-flashing the ecu back to stock will clear the boost history. Would be a good question for race box to verify.
This is where rapport and due-diligence comes into play. If you need convincing, simply drive to Nissan and ask a service manager in person. Your direct questioning in person will be met with transparency and appreciation for taking the time to show up and ask 99% of the time, and no, they aren’t going to ask what you drive or who you are to answer that question. @Racebox would be great to ask but only because of their reputation, despite offering tunes, they would not evade or be misleading about it.
Lastly, if you search the internet in a way that will yield unbiased (subconsciously or not) results, it will spew definitive results. I.E.
“- ECU Data Logging: Modern ECUs, including those in the GT-R, store a lot of data about how the car has been driven and any changes that have been made to the system. This data includes information about peak boost pressure, which can indicate if the car has been run with increased boost levels beyond the factory setting.
- Flash Counters: Some tuners might claim that flashing the ECU back to stock will erase any trace of tuning. However, the ECU keeps track of the number of times it has been flashed. This "flash counter" can show that the ECU has been rewritten, even if the current tune is the stock one.
- Nissan Diagnostic Tools: Nissan has sophisticated diagnostic tools that can delve deep into the ECU's data and logs. These tools can potentially detect signs of tuning, even if the tune has been removed and the flash counter reset (though resetting the counter might be seen as further tampering).”
Source: Google.
Don’t forget that non carb approved ecu flash will not pass California smog.
if you re-flash back to stock, will it pass the carb approval? Z1 offers a carb legal ecutek tune.
Source: Google.
Of course the ecu stores history and nissan can dig into the ecu’s history. nothing new/ modern - that has been the for decades.
question is what variables are cleared when reflashing the ECUTEK tune back to stock? there is not a lot of ecutek tuning info on the net. An ecutek master tuner can better answer the question. a stealership would be the last place i would look for service out side of warranty and certainly not for tuning info.
What’s the probability a service tech will dig into the ecu for tampering answer: it depends….
for normal service / repairs a service tech is not going to call in a master ecu tech to check for tampering. But if they do and see the ecu has stock program & current rev, then he will be less concerned with flags & the flash counters.
We have a member that washed his engine had a sensor failure and was having boost spikes of 20+psi when shifting. the early autos were reflashed for tranny issues.
there risk of warranty coverage with any form of tuning - if you roll up with a blown engine its a safe bet that you are screwed.
I don’t understand how a dealer can’t see that stock boost was exceeded.
They certainly can - question is what was the cause - there are lots of possibilities
the question i have - can tuning software like ecutek clear the boost history?
Racebox
Diamond Sponsor
Racebox
goracebox.com
2023 Nissan Z
Tuning/ parts installation
Hello,
There's no way to truly hide it other than swapping in a new ECU or keeping a spare one on hand. Even then, there may be other modules that store data that can be accessed by Nissan Field Engineers. But dealerships don't have the field engineers hanging around. They are dispatched from Nissan when there is a case that needs investigating.
In terms of what the "Flash back to stock" does - it just puts the stock calibration back on the car. All modified values change, but the flash counter can still be read. There is a way to clear the flash counter on VR30s by removing the battery and letting the car sit so that all modules completely die and then if you check flash counter on the EcuTek programming screen, it will show 0. However, this doesn't mean that the ECU isn't storing a different flash counter that cannot be reset.
But again, 99% of the time, flashing to stock is all that matters. However, if the dealer/Infiniti/Nissan decides to investigate the case, a field engineer will be able to know the car was tuned.
TexasZee
Hello,
what's your opinion on the plug and plays? Will increase boost readings show it had some sort of tune? or will it be chopped up to the unknown/no way of telling.
Racebox
Diamond Sponsor
Racebox
goracebox.com
2023 Nissan Z
Anything that monitors the ECU parameters will leave some sort of trace
NocturnalEmber
East coast
24 Z Performance
I would not be surprised in the least if Nissan had the flash counter stored in NVRAM that persists through a power off/battery drain, especially when dealing with warranty claims for substantial amounts of money.
Ford did this on a lot of their ecoboost cars as an example; it's a fools errand to risk being on the hook for thousands of dollars in repairs because they "might not" check or that there might not be a flash counter stored in the ECU that persists.
If someone has access to Consult 3+ It's probably in whatever section deals with ECU/PCM
updates.
Now if you don't care about warranty coverage, that's a different story.
Hello,
than you - good information. that has been my point with recent discussions- it’s a low probability that a routine repair would trigger an investigation.
if it’s a blown engine, then yes nissan will check the ecu. specially if you have decals across the front windshield “900HP ECUTEK TUNED”. lol.
