2024 Nissan Z - Stock Exhaust
wjPossum
James
Cincinnati
2024 Nissan Z Nismo
Owner/Operator Milford Lube Express
I just did an exhaust swap and removed these from my Nismo exhaust with a 1/2 inch wratchet and socket with no issues at all. Maybe try an extendable ratchet for leverage?
wjPossum
James
Cincinnati
2024 Nissan Z Nismo
Depending on what type and size impact "drill" you are using. Some are really weak. Get a long wrench or a breaker bar and put some muscle on it to crack it loose. Then you can run it off with the power tool.
wjPossum
James
Cincinnati
2024 Nissan Z Nismo
You definitely don’t need a power drill for any part of this install except to maybe run the bolts up onto the screw quicker. PB blaster might help but you shouldn’t even need that.
Landon
Landon
United States
How did it go Landon? What exhaust did you end up getting?
The jack stands I was using did not give enough space underneath the car to work. So I ended up taking the Z to a muffler shop. The muffler system I put on the Z is the AWE Track Edition exhaust system. The sound is fantastic! A much improvement over the stock exhaust system.
AlanZ
Alan
Civil Servant
Can you post a sound clip?
Landon
Landon
United States
You can check out this YouTube video from AWE:
My recording with the iphone is not so good. AWE video got better recording technologies. Listen to the part in the video for the AWE Track version with NO down pipes. Also, the video is good but does not do justice to real life sounds. You really need to be there to get the real experience.
SneauxMan762
Robert
Louisiana
2024 240Z P-MT, 2022 C8, 1967 Chevy II Nova
Every video Ive watched folks have caught hell with the bolt tightness. They've always used a cheater pipe or breaker bar. It sounds like they break the bolt every time one lets loose but they're just that tight.
AlfredoGonzalez
Qatar, Doha
Nissan Z Proto
Any drone with the track edition?
IMHO, if you’re going to work on a car an impact is a necessity. I got one with a Milwaukee bundle like 15 years ago thinking I wouldn’t use it much and it’s pretty much the only drill/driver I use unless I’m drilling holes. Sling a few bucks at Harbor Freight. Guaranteed to be worth it.
Landon
Landon
United States
I got the AWE Track Edition exhaust system. I had a professional installed the exhaust system for me.
No drone for me during highway speed limit. I was able to enjoy my music and have a peaceful conversation with a person sitting next to me without screaming at each other.
ā€˜25 PRFM M/T Gun Metallic
just removed my oem M/T muffler axle back and installed the oem A/T axle back. Aka muffler delete mod.
my breaker bar was too big and no room for a my cordless impact wrench (pistol style). you need a low profile right angle impact wrench, ratchet with a cheater pipe, or standard box wrench.
i used a box wrench and lightly tapped it with a mallet to break the flange nuts loose. They are not bad to remove. I did use PB blaster on the nuts.
yellowz6mt
24 Z Performance 6MT
How does this sound?
@yellowz6mt
I like it - it added the much needed volume. i can still have a normal conversation and listen to the radio. But when i get on it, there is a decent rumble. It should have been setup this way from the start. Makes me think this was Nissan’s original design but added the muffler to pass japan’s noise requirements
The attraction for me was keeping the stock tips. If i didn’t care about the keeping the stock tips, i would just do an after market ā€œmuffler deleteā€.
yellowz6mt
@yellowz6mt
Thanks for the reply!
