2024 Nissan Z Perf - Torque reversal pop - SOLVED -
Technomancer
Ontario, Canada
2024 Z Performance MT
Having an ongoing issue... It makes this mechanical pop when changing directions. Sounds like a dull thud when reversing, but a loud pop going forward. The videos don't do it justice and it feels worse than it sounds.
I can also make it happen while cruising if I let off the gas and hit the pedal again so I don't think it brake pad related.
Had it at the dealership multiple times already and about to go for round 3 - just looking for additional opinions.
I was underneath and checked torque on all the bolts on the rear end - found some loose on the brace but the issue persists
Yeah that does not sound good or "normal". Beyond that confirmation I'm no help on diagnosis.
Do you have aftermarket catback AND underbody brace? Others had those touching each other, clearance issue. Or, maybe driveshaft, how many miles on the Z?
Technomancer
Technomancer
Ontario, Canada
Aftermarket exhaust, yes. OEM brace. I double checked the exhaust wasn't resting or rubbing on anything. no issues there from what I can see
Technomancer
Technomancer
Ontario, Canada
Coming up on 20K km. It's definitely something in the back end. It won't do it with the clutch in, only when I send power to the diff. sometimes it will pop when going around corners as well.
Also, weirdly enough, some times it goes away. I can drive to work without a sound, then acts up on the way home.
Ambient temperature doesn't seem to affect it either - happens at 6 degrees just as much as it does at 27
Have you checked or replaced your rear differential fluid? If not, you're likely due for a drain & fill. Has the dealership been able to isolate the noise? To be, it sounds like something is binding... I'd check the driveshaft & axle joints as well.
Technomancer
Technomancer
Ontario, Canada
I'll have to check the fluid once I get it back if the dealership doesn't.
They did the re-greasing with the M77 last year and installed newer revision axles as per whatever TSB they were following.
I took them apart this year and did the same thing - no change.
There is some backlash in the drive train when I move it by hand with the rear wheels in the air - I'm not sure how much is supposed to be normal though.
Neutr0n
Alberta
AW11, 3IS250, RZ34, ST185
nissan had the same problem when i worked there back in 2007 lol we were told to grease the splines with moly grease
Is it the e-brake dragging a little? The E-brake has front to back play in it even when engaged all the way and will pop a little if you rock the car back and forth with the e-brake on. There is slight gaps in the tabs the shoes are mounted too that causes the play.
Pragmatist
North Florida
2026 Z, 2003 Corvette, 1967 Chevy II nova
If it was an older car would say it was a motor mount.....
I think you found the problem area.....
SleepyD7
Gainesville Florida
Audio Video Integration Sales
I could get my Z34 to pop or creek similarly whenever I disengaged my parking brake and started to move. (?)
Technomancer
Technomancer
Ontario, Canada
I can ask the dealer to look into that. Or I will once I get it back
