2023+ Nissan Z Spare Tire kit.
trajiiic
Nashville, TN
'26 Z Heritage M.N.P., '19 Tacoma TRD Off-Road
IT Guy
I purchased a spare tire kit from ebay and installed it. The fitment is about 98%. The jack and accessories took some effort to fit into the slot. perhaps a different kit would have had more a more OEM accurate jack.
fortunehunter
Zach
Virginia
2025 RZ34 Performance (MT)
I was always curious about this. Have you noticed any difference in the audio system with the sub in the rim?
Larry
Larry
Lawrenceville, GA
2024 Heritage Z
Retired electrical engineer
Suggest you actually mount the wheel front and back to make sure it will work. I did with mine and have peace of mind. The wheel must have a very deep offset to clear the brake caliper, especially in the rear.
trajiiic
trajiiic
Nashville, TN
IT Guy
That's a great idea! Is yours the same wheel?
Larry
Larry
Lawrenceville, GA
2024 Heritage Z
Probably the same. I got off ebay from a junkyard. It was from another nissan model. Don't remember what, but found the info from another thread in this community. I also got the tow hook and made sure it fit. That was part of the normal emergency kit that Nissan stupidly decided to not include with the Z. A pump and can of fix a flat? What a joke, especially since the space is available for the full spare kit, including the subwoofer.
Good call...excellent advice!
If that's an issue, I if you can buy just one 20mm or 30mm bolt on wheel spacer.
trajiiic
trajiiic
Nashville, TN
IT Guy
The tools do not appear to be OEM.
You're right. Lesson learned for others. check to make sure it's the silver jack and tools. Though, this should would.
papozalsa
Jose
Virgina
Z 2024
Team Lead QA
Remember the chasis is the same as the 370Z, the spare from it fits in the trunk space and it should fit all 4 sides of the Z.
