Will these wheels fit?
Landon
Landon
United States
I am looking at some wheels or these sizes but not sure if they will fit the 2024 Nissan Z:
Front: 19x10 (35 offset)
Back: 19x11 (50 offset)
Thanks for any advice!
Compared to the NISMO fitment:
Front should fit fine. Same size, but shifted in 2mm.
Rear is a different story. Inner lip sits 34mm further in, and the outer lip tucked 20mm.
Running a 30mm spacer on the rear might work, but I’m not certain.
With a 30mm spacer the outer lip would sit like a NISMO with 10mm spacers (or a Perf with 23mm spacers). The inner lip will still be 4mm further in, about 1/8ā€, and I assume there’s more than 1/8ā€ of suspension clearance on the stock NISMO.
Landon
Landon
United States
Alright, I found 2 more sets and I believe these sets are getting closer to fit my Z:
FRONT: 19x10 (35mm offset)
REAR: 19x11 (24mm offset
REAR: 19X11 (25MM offset)
I am trying to find a set that does not require spacers. Which set above is the correct set? If neither of those sets will work, I will continue to look further.
ForSale24
Ron G.
Phoenix
Work Wheels ZR10 19x9.5 +23
Work Wheels ZR10 19x10.5 +15
Michelin Pilot Sport 4S 265 & 295
This is my set up, it's kinda an aggressive fit with no room to "push" out or in. You can almost see the "tire hairs" poking no spacers... A +50 offset just sounds all wrong. Stock is +23 in the rear
REAR: 19x11 (24mm and 25mm offset)
The 1mm rear offset difference isn’t enough to matter. Between those two consider which one you like more vs the price.
Front practically identical to the stock NISMO front. That would be 13mm further out than a stock Perf. To get the same look as @ForSale24 on the front you would need 12mm spacers.
Rear would poke 6mm further out than a stock NISMO. Almost indistinguishable from ForSale24’s rear (2mm or 3mm inset). Inside clearance is unknown. Inner lip is 7mm or 8mm (0.28ā€ to 0.31ā€) further in than the stock Performance rears. I assume there’s 1/3ā€ to play with back there, but zero guarantees from me.
You need to poke around https://www.willtheyfit.com/
Plug in a few spec’s and it will do all the math for you.
Landon
Landon
United States
I found a set of wheels that I really like but the back wheels got offset at 56MM. Would a 25MM or 30MM wheel spacer be good?
tractng
Los Angeles
2022 Miata, 2009 BMW X5
Infrastructure Manager
Very nice!! Is your car lowered? Btw, my GF lives in Phx. Can you send me the info to the shop you purchased your rims? Thanks. ahead.
TT
Assuming they’re 19’s, for the rear with a 56mm offset:
10ā€ = 30mm spacers will poke like OEM Perf with 4mm spacers
10.5ā€œ = 30mm spacers will poke like OEM Perf with 10mm spacers
11ā€ = 30mm spacers will poke like OEM Perf with 17mm spacers, BUT the inner lip will be 9mm (0.35ā€) further in then OEM and I don’t know how much inner clearance is available Past the stock fitment. 35mm spacer may work inside and out, if someone makes them that big.
linebacker14R
Steven
Venutra,Ca
2024 Nissan Z Performence
Test Car Driver
Rocking the exact same specs but the bronze...
ForSale24
Ron G.
Phoenix
TT
I brought them new from Japan. Work wheels are "made to order" The shop that I'm at in this picture is for my coilover "corner balancing". No I didn't lower it (hard enough getting up the driveway) the tires are kinda chunky. PS4 sidewalls are beautiful, just looks filled in
tractng
Los Angeles
Yes I know the wheels are made to order. What I meant was what shop did you go through to buy them?
Also what tire size are the front? 265/40?
ForSale24
Ron G.
Phoenix
Yup 265/40... I ordered from MartiniWorks.com I ordered wheels, tires and coilovers during a black Friday sale. Got free lug nuts or wheels caps maybe both. If you can wait for the sale it's worth it. Coilovers came from Fortune Auto in Jan. Wheels came end of Feb.
I love the color for any car but yellow. I don't have a proto, so bronze will always be a no for me lol... I wish Work had other sticker colors for us. Red or green isn't enough
ForSale24
Ron G.
Phoenix
ForSale24
Ron G.
Phoenix
linebacker14R
Steven
Venutra,Ca
Test Car Driver
If you go to works web site they have more I think...
