Steering wheel lock
toycar
Jeanette
Ottawa Ontario
2024 Performance Nissan Z
I realize if someone really wants to steal your car they will. But I am hoping this will deter the half hearted thief. Car and driver said they could not break it with a drill, hammer or bolt cutters. It is heavy too. The box says it would take 45 minutes to cut through all three parts? Tevalphee steering wheel pedal lock. $62 canadian.
Bumflik
Issac
illadel
Bus Operator
I had one of these before. Get a hardwired 'Kill Switch 'which is my next move. If ya Car is in the wild It can be loaded on a flatbed tow truck and going in 60 seconds. But anti theft devices like this makes it difficult for smash and grab low level car thieves. I have. A Smart Tag and GPS Tracker. Also. My Vantrue Dashcam has 4G LTE cellular with built in GPS tracking as well allowing for connection for instant communication in and around my vehicle.
If well made, those are so effective that if they want the car bad enough they’ll cut the steering wheel to remove it. Even with well made ones the weak point can be the lock cylinder, which is the case with almost everything with a lock cylinder.
That thing’s an oldie but a goodie!
Hidden kill switch is a classic. And effective. But I’ve never tried it myself.
Bumflik
Issac
illadel
Bus Operator
I have a coworker who has an automatic trans Performance Z. His was stolen but he recovered it. Autos are cake to steal due to most of the population has no manual transmission driving experience. But he located his car with the hidden Apple Air tag. I have an Android Samsung Smart Tag . Bottom line all theft devices make it difficult by adding valuable time to make it hard to just get in and go for the thief. But if they have a tow truck they can just take the entire car .Get GPS trackers and Tags to locate the Auto locating.
How does a modern car get stolen?
Does someone have a key fob cloning device? Did they steal the keys?
Back in the day when I used to install car alarms, our favorite trick was to wire the ECU key-on circuit through the driver's side seatbelt latch circuit. Thieves almost never buckle up before trying to start the car (they almost never buckle up afterwards either if they get the car running), so they get majorly stumped by that trick. We'd wire it in to look totally factory, a thief could find the alarm brain, but the seatbelt trick is not wired with the alarm brain.
‘25 PRFM M/T
How long would it take to cut the steering wheel with a good bolt cutter?
If you are stealing the car, repo / tow truck is the way to go. Nobody will take a second look in broad daylight. Everyone just thinks you are behind on payments, illegally parked, it won’t start., etc. just need a sign on the door “repo man / towing service”.
repo man - used car lots - chop shops maybe the same folks? - 3in1 turnkey service - lol
My original career was as an adjuster, then a supervisor, and then a national manager in the fire, theft and vandalism claims team for a top 5 insurer for 20 years.
Most legitimate thefts of modern vehicles are tow aways, straight into a container and off to Africa or the Middle East where they are made to work again. Very few stay in the USA.
Key fob replicators are highly illegal under federal law except for legitimate uses like dealerships and locksmiths. Heavy prison terms if you are caught with one and you have to sneak it into the country somehow. They also take more time than a simple tow, so they are relatively rarely used.
The vast majority of modern thefts, the kind that end up burned or stripped, are fraudulent and most of those are caught. The insurers have been doing this for 100 plus years, they’ve seen your best laid plan to get out of your car payment before, pal!
Steering wheel hoops (?) are typically mild steel rod so they bend if you slam into it. With hefty bolt cutters mild steel is no problem. I don’t believe it’s typical for car thieves carry 3 foot bolt cutters, but it can be done…or so I’ve heard. :LOL:
