Sound deadening
staying_tuned
Kentucky
23’ Z Performance Manual
Hey folks, I just wanted to mention that the reduction in NVH as a result of deadening the trunk, floors & doors has been amazing. I'm midway through a budget bose upgrade but the improvement is so great that I'd recommend doing this regardless if you plan to upgrade your audio or not. The end result will be a far better sounding stock system and FAR less fatigue from road, chassis, interior & exhaust noise. I spent quite a bit of time in a Porsche C4S and was astounded by how quiet that car was despite being so densely packed with capability in such a small package. I could drive it from sun-up to sun-down and not feel wrecked and I realized most of that was simply due to it being peaceful inside. I remember the only sound that stood out when not deep in the throttle was tires working.
That is what the Z sounds like now, just tires working. Music doesn't have to fight for priority and while the motor & exhaust are certainly present, they aren't intrusive. What is entirely gone is the creeks, pops, clicks and trailing shakes and vibrations that occur after every bump in the road and close of the door or trunk. If I had to sum it up, I'd say all of the incidental noise you find in anything under $85k-ish is gone. That's no bash on the Z, it's a masterpiece at the current price-point but they can only do so much. You'll notice as you reveal paneling that they tried to do what they could, a bit of factory deadening is in place but nothing like you'd see in a euro sports car etc. A weekend of part-time work will address that.
The work is straight forward in our car too, no need to gut anything. The seats come out very easily and that would be the absolute hardest part, the rest just takes a bit of time. I'd suspect you could deaden the trunk, floors and doors for well under $100 in deadener. Weight-wise I've likely added just shy of 20lbs of deadener but boy does that 20lbs make a difference.
Here are some tips in case you do it:
- Trunk: Very easy and some of the most bang for your buck. Just pull all your carpets and foam inserts. Deaden what you can see, here is a post from when I did mine.
- Floor: Lucked out on the floors for our cars as far as accessibility is concerned. Fold your seats all the way then move them all the way back. Pull the 2 front bolts on each. Then move your seats all the way forward to access the rear two bolts and remove. Tip the seats back to unplug the adapters and pull them on out. From there you need only pull the door lip trim and the forward fuse panel cover/kick-panel area. Unclip the carpet from the holders and bungee cord it up while you deaden. This will give you enough access to cover 75% of the floor, here are a few shots.
- Doors: These have to be the easiest door panels to pull, even easier than the 370 & 350. Pop off the triangle by the handle and the access panel midway down to expose a total of 3 10mm bolts. Remove, Unplug the 3 grouped electrical connectors and pull the lines for the lock. These are simple enough to do nearly blind. Then pull the corner reflector so you have a good handle to simply yank the door panel off. Unlike most, these down sit on the window track, they literally just stick to the insides of the door via clips and 3 bolts.
Ok hope that helps anyone looking to sound deaden the car.
What thickness of deadening did you use?
I used some thick puffy stuff in the trunk well. I think it would cause fitment issues when putting the seats back in.....
staying_tuned
staying_tuned
Kentucky
The puffy stuff you used might have been closed cell foam, I use that in certain areas as a supplemental layer or I use cut down strips of it to hold down factory wiring in places where it looks like it might be wiggling around. 98% of what goes down is the thin aluminum/rubber butyl backed sheets. None imped fitment of clips, carpet, seats etc.
Here is a pic of what I used on the Z:
Far left is absurdly thick at 120mil/3mil. This doesn't sound like a lot but it's a bear to roll so I only buy a little of this and affix cubes here and there to build up the thinner stuff as needed. This stuff works very well.
Middle is the workhorse, this is about 50mil and really easy to cut and roll out. You can mold this stuff into position with your fingers. It all should be rolled of course but its very easy to work with.
Far right is the closed cell foam I mentioned above. It doesn't actually deaden all that well by itself but synergizes very well with the aluminum rubber butyl backed products.
Interestingly my Sport A/T has no noise cancelling or fake noise, and by being A/T is also louder. I think it sounds great.
It's funny you mention making it quiet, I am coming from an S197 Shelby and ZO6 and to be honest, the one thing about the Z I am getting used to, is how quiet it is. I can barely hear and drivetrain noise, there is almost no wind noise and it seems so refined, I need to remember I am driving a sports car.
staying_tuned
staying_tuned
Kentucky
Huge coyote, roadrunner and voodoo fan, man those 302s are sweet and the Shelby variants are timeless. Never was an LS guy but only because I only have 1 lifetime. I’ve got a coyote in my F150 with a Vortech blower at 11psi, it’s rowdy as hell which makes the Z feel so refined and precise. Coming from a Z06, the Z must sound like a coffin hah. I diverted a ways back and dove into turbo awd platforms after a few supercharged coyotes. With the exception of a GT-R and Q60 red sport, all were German and honestly the attention to detail on interior acoustics (especially audi) ruined me. Unless it has a rip snorting V8 or a 12v/24v oil burner, all I want to hear is the sound of a few cylinders and a few turbos making gobs of power.
I can understand how you feel, I had an Audi RS4 back in the day, V8tt, 450 HP, and when you close the door, it was like you were in a vault. I even had a Milltek valved exhaust (people think the Nissan Z exhaust options are expensive), and I could only hear it with the windows rolled down.
manesag
2025 Nissan Z Sport
@staying_tuned did you notice a big difference by lining the trunk? I was thinking of two layers, one being something like a dynamat or the Amazon basics stuff, and some foam ontop of it. Mainly trying to reduce road noise in the trunk
staying_tuned
staying_tuned
Kentucky
Absolutely, but I'd try to get up around the sides over the wheel arches & shock tower. Those rear wheel wells, when deadened, made a tremendous difference suppressing road noise. If you can suppress it early (at the wells/trunk) the vibrations can't make their way to and rattle all the fiddly-bit panels held together by plastic clips and such. You won't be disappointed.
manesag
2025 Nissan Z Sport
Heck yeah, that’s what I wanted to hear, I know you showed some products that you used in a previous post, was there any specific brand to look at?
staying_tuned
staying_tuned
Kentucky
NVX, Siless and Kilmat have all performed equally to or better (not just acoustically but also ease of install) than the higher-dollar, often hybrid lines from folks like Dynamat. I feel like all the big brands had to make up things to justify their price points when even home depot foil-backed duct insulation will get you 75% there. I typically like to run 2 layers of something thin in rattle prone areas vs. using ultra thick stuff. The thick stuff (80 mil or higher) is hard to work into crevices or tuck nicely over and around bolt heads, latches etc.
With the cheaper stuff you can buy much more. Over time you'll have enough left over from projects to do things like deaden the back and sides of your dishwasher, back of the fridge (near compressor) etc. This will yield huge bargaining power with your significant other. I can damn near quantify how much power my project vehicle has gained simply from deadening things that were not as pleasant as they could be around the house : o ).
Xylander
Guy
2024 Nissan NISMO Z
The shop that did my Focal system install used almost 30 pounds of 4mm thick Sound Shield mat. They removed my entire interior and put it in the doors, under the headliner, around the rear hatch, trunk, even on the back side of the license plate. You almost can't hear people talking outside the car when the windows are up.
The Nismo is built like a race car from the factory with very little sound deadening anywhere in the car. That has been overwhelmingly rectified.
Need to remove some trunk stuff to Install remote damper adjusters and thinking about adding some sound deadening while I’ve got everything accessible. Never done it before.
Thinking Kilmat, as it appears to be pretty good, and way cheaper than Dynamat. Any suggestions from you pro’s on thickness, what’s necessary and not, how many sf to make sure I’m covered, or anything else I should know?
TIA
