Safe Jack points
Madgud
Nissan Z Proto (Manual)
On the oil subject which brand and grade do you guys swear by for this car?
tsungfuyao
Tsung-Fu
CA
I wonder is that right to jack up from the portion where I circled with "A"? Also anyone knows what is "B" for?
Madgud
Definitely don't jack up from anywhere in that A section. B is actually the designed spot just for that.
Here you go. They are the same for the Regular Z as well. I prefer a scissor lift with pads for these Z cars. There is a spot along the frame seams with 2 notches front and back. Look at those tiny exhaust pipes? ugh
This is what I did with my QuickJacks and the blocks I have got kind of "dented" you can see on the left two that were on the front but it seemed pretty darn stable (I put actual jacks under my QuickJacks just in case). The one on the bottom is an example of thepinch-weld adapters for the QJ's but the slot is too deep on the block (hard to tell in the pic) and the block is too wide it would hit the body on the outside. I wish they were skinnier. So I just used the normal blocks. Hopefully they hold up for some more lifts of the car.
D2M
Nismo Z, Veloster N, Ram 2500
I use hockey pucks on my jack stands and jack, never any metal to metal contact.
MacCool
central Minnesota
2024 Performance Z
Me too. I bought four pucks, cut a slot in each with a table saw so they’d fit over the frame rails, then drilled holes and glued magnets (neodymium from Amazon) in so they’d stay put against the rocker panel.
