RZ34 Interior Accent Lighting option - Your thoughts?
Avery
Avery
Thousand Oaks, CA
'77 280Z 5-Speed
I went to a dealership yesterday to specifically look at the Interior Accent Lighting option (it was in a MY26 Performance) and I was BEYOND underwhelmed. It's $480 and factory-installed, and it was very hard to see the colors (I only saw around 5-6 different colors: something like white/yellow, red, green, blue, and purple). The lighting is ONLY in the footwells and nowhere else which makes me question why it's so expensive. It seems like a design afterthought by Nissan and something you could just pick up from Amazon for $50 (not that I would, but I'm trying to emphasize how simple and anemic this option really is). I could understand the price if the lighting included mood-inducing pinstripe-lighting along the dash and/or doors but this isn't the case. And when you look at the nissanusa website's photo of this option, it's now obvious to me that even in a a really dark photo trying to highlight this lighting, it's actually quite anemic. The on/off/color switch is located on the lower left dash approximately in front of where your left knee is positioned.
For those of you who have this option in your Z, can you let me know your opinion? How does it look at nighttime or in the complete dark? Did you spec this option in your build, and are you happy with it? I'd really like to consider if I should remove it from my build. Thanks!
While I usually prefer OEM, I agree with your assessment of the Nissan option for our cars, and went the govee route. I have thousands of color choices and all sorts of lighting options. Been running them 2 years and still love em.
beergeek
Glen
RI
The Nissan option shows OK in the dark and also illuminates both cup holders, which is the reason I installed it.
I couldn’t see where to put my Hydro Flask in the dark.
Avery
Avery
Thousand Oaks, CA
'77 280Z 5-Speed
Phenomenally different, truly a night and day difference. Thank you for taking the time to reply. I just might now go that route instead of OEM.
Avery
Avery
Thousand Oaks, CA
'77 280Z 5-Speed
I thought the lighting is only in the footwells; had no idea about the cup holders. Appreciate your input.
haohmaru
Gregory
New England
24 Z Perf / 13 WRX
Nice, what model did you install? How is it powered?
Govee Lights
I chose the 12v, you can also do USB. The 12v was a cleaner install in my view. the plastics for the center console and along the door kick plates hide all the wiring. I put one light strip under each footwell and one light strip under each seat, they light the cabin perfectly and you cannot see any of the LED strips.
The only thing visible is the 12v plug and about 2 inches of wire coming from the 12v plug to under the center console. I would have just thrown it away and done something different if it was not a clean install, I'm not about to have a junky set up in this car.
I also bought better two sided tape, a more heavy duty version than what comes on the back of the strips to make sure they stay in place. No issues.
I use the govee app for colors rather than the remote although the remote does work well.
