Recommendations for LSD
Neutr0n
Alberta
AW11, 3IS250, RZ34, ST185
I’d like to add an LSD to the Sport Z for next summer. I’m leaning towards a clutch type 1.5 way. I have OS Giken in mind but do you guys know any other brand that are better value?
Ckynus
Film
I got mine from Z1
Z1 2023+ Nissan Z Street Pro R200 Limited Slip Differential
See if Quaife has one for our Zs. I had the mechanical helical in the 240Z R200, bulletproof!
Do a search for LSD <and> Mugzilla
I kicked around having one built out. I just bought a NIB LSD from Nissan Parts for a 2024 6MT performance. Swapped out my open pumpkin for the new LSD.
I have my stock open 2024 6MT pumpkin in a box. If you are hell-bent on building out one, perhaps buy a used Sport pumpkin, so IF your shop doesn't set the lash correctly and it eats itself, you still have a stock pumpkin so you don't lose use of your car while it gets redone.
(Mine is listed in the equipment exchange....)
manesag
2025 Nissan Z Sport
When you swapped to the performance pumpkin, did you just disconnect the axle and drive shaft, swap pumpkins and connected everything up?
I used the Z1 diff cover, as the stock 6MT performance LSD diff did NOT have the breather installed. If I was installing a breather onto the stock cover, I would not have the balls to hammer one in and possibly introduce shavings in to the pumpkin. I installed the Z1 breather BEFORE installing the cover onto the pumpkin.
You described the swap process exactly. The rear triangle brace gets removed. I dropped the exhaust too. I had extra Adams Ceramic, so I ceramic-ed the pumpkin, and above where the muffler goes. Why? Because I was using a lift, had the time, and am anal-retentive. (And I share too much.)
I used RedLine fluid, as it already had the LSD additive in it. And it made me feel special, because I have an inferiority complex, and I think the stock Nissan LSD fluid must be the bottom-of-the- basement quality stuff.
