PPF pricing?
NocturnalEmber
East coast
24 Z Performance
Had a quote done for PPF - seems a bit excessive, but as I don't know the going rate I feel like I'd rather ask here and get some opinions.
Price quoted was $6,000 ~
This was for a full body ppf with a detail/clean before application and paint correction.
Even still, this seems kinda high? They use Suntek I believe, and I think it's also based on a pre cut kit.
BeShizz
Bee
Santa Clarita
2025 Nissan Z
What kind of PPF? The good quality will be expensive, but 6,000 is on the expensive side. I was quoted about 4,500 for full Xpel PPF
Zhoop44
Ron
Western Ma.
2024 Z Heritage
Accountant
It is very location dependent. Number of installers in your area, etc. I had a Gr86 done without paint correction for $5,500. 3M Professional. I ate the entire cost when I traded it in for my Z Heritage. I thought I keep the car for a long time but grew tired of it. PPF is great but my advise is don’t do the entire car. Do the front panels and headlights and save the cash. You will recover ZERO if you have to sell car. Good Luck. 🍀
chadgigachad
$6k for full PPF is a bit steep. Maybe you can work something else into the deal (ie tint).
NocturnalEmber
East coast
24 Z Performance
I already have 3M ceramic on the front and rear window, not much else I could really work with. They are a higher end place, but $6,000 seems pretty up there if they are using the pre cut kits. I could see paying $4,000~ but 6 seems up there. I wasn't expecting it to contribute to the value so much, but I thought it might at least insulate it or give it a benefit compared to one without it. I have no plans to sell the car as it is now anyway, though.
Howdog70
Howard
Los Angeles
240Z
This is a useful response. Unless you intend to never, ever, ever sell, it's a loser. There's no return. I paid 7k for full Xpel ppf and full ceramic tint.
vheiskell
Vernon
Channing TX
2024 Nissan Nismo Tri-Coat Passion Red
Locomotive Engineer
That’s a tough one! It mainly depends on how paint work they have to do before applying. I paid $4,100 to have front clip, 10” on the roof, behind rear wheel wells, and rocker panels. They’ve had my car 3 weeks getting it ready to apply I had a few rock chips and they want it perfect. So…anyway I’m a firm believer in you get what you pay for. So no, if they do it right, I don’t think it’s too much at all. My guy using 3m stuff of some sort
Wangan_Z
Jimmy
Mississippi
2025 Nissan Z Performance Manual 1983 Nissan Skyline RS-X Turbo
Aerospace
You get what you pay for when it comes to PPF. That sounds about right for a full install from a quality shop that has a lot of experience with PPF. It's not like installing a vinyl wrap. Totally different beast and characteristics. You only get one shot at PPF installs whereas you can pull up mis-laid film and re-position with vinyl wraps. I've had 8 cars done up with full installs and I can tell you that you are not paying as much for the film, you are paying for the prep, labor and after service. The material cost is pretty much set at around $1300 for one of our cars. That's for full coverage Xpel Ultimate.
Approved Xpel installers use DAP software to cut the kits. A good shop will extend the edges of the kit template to give you nice wrapped edges...highly recommended for light colored cars or matte film installs as dirt will tend to accumulate around the edges of the film on a standard kit. A really good shop will do bulk installs on bumpers that can cut down the number of undercuts and seams in the install. They will also do a full paint correction and should touch up any paint chips prior to install.
I learned the hard way on the first PPF install I had. The shop cut corners and the install looked horrible, but they under cut their competitors by thousands. It took a claim to corporate for them to fix what they screwed up as they refused to to re-do their work. I learned that price will effect quality and pride put into their work.
vheiskell
Vernon
Channing TX
Locomotive Engineer
You get what you pay for when it comes to PPF. That sounds about right for a full install from a quality shop that has a lot of experience with PPF. It's not like installing a vinyl wrap. Totally different beast and characteristics. You only get one shot at installs my it right whereas you can pull up and re-lay a wrap. I've done 8 cars with full installs and I can tell you that you are not paying for the film, you are paying for the labor and after service. The material cost alone for one of our cars is $1300 for Xpel Ultimate.
I learned the hard way on the first PPF install I had. The shop cut corners and the install looked horrible, but they under cut their competitors by thousands. It took a claim to corporate for them to fix what they screwed up as they refused to to re-do their work. I learned a lot with that install that price will effect quality and pride put into their work.
This is THE answer! No other answers matter!
NismoNed
The Racing Capital of the World
2024 Nissan Z Nismo, 2025 Nissan Sentra SR, 2025 Nissan Rogue Platinum
I had a full frontal done on mine for $2,700 by a very reputable PPF shop here in Indy. 6k although on the higher side, doesn’t seem completely unreasonable for an entire car.
I’ve probably had 10 cars PPF’d. In my experience, you get what you pay for. Just my two cents.
Garage King MI
Jason
Ortonville, MI
2024 Nissan Z Performance M/T
Manager - Turbine Engine Maintenance Shop
$1975.00 for front bumper and hood (Xpel Ultimate 10 mil., with “wrapped edges”.). Highly reputable shop in Troy, Michigan.
