LSD options?
ujnx2000
rz34
If I understand correctly, the LSD in the 23+ Z is a clutch type.
What are the pros/cons of it over a helical type?
The helical would outlast a clutch type, so why do you think Nissan choose it?
Clutch type "wears". Helical ,if it effs up, you have bigger issues as either lash, or it eating itself.
If you are beating the crap out of your LSD that bad, you are a racer or drifter.
D2M
Nismo Z, Veloster N, Ram 2500
Clutch type is usually a 2 way or a 1.5 way, that means its active during acceleration and deceleration. It can also chatter at low speeds when making tight turns. Its also tunable in how hard the lockup is and how quickly it can come on, but has to be disassembled to make any changes. Depending on the brand it may require special oil.
Helical type is a 1 way, its only active during acceleration and will only work when both wheels are touching the ground. Has smoother operation when just cruising around. No special oil is required as there are not clutched inside and less frequent oil changes required.
ujnx2000
ujnx2000
rz34
How often are we supposed to change the oil in the rear diff?
Ah ok.. i found it...
every 20k miles
ujnx2000
ujnx2000
rz34
and i see brake fluid should be changed every 20k also...
I have a factory brand new LSD on the way from Nissan. I plan on putting the Z1 bigger cover on it.
Doing a bunch of reading to figure out what fluid / break in additive (If any) I should use.
Putting in the urethane bushings too.
5thZ
Atlanta
Does anyone know of the best aftermarket alternatives for LSD? I see on Conceptzperformance they have a few choices but I don't know right from left on the drop-down options.
https://conceptzperformance.com/cus...ion-mt-nissan-2023-z-rz34-lsd-2a5_p_79522.php
My purpose is for tracking the car
So, when you say TRACKING.....
Do you mean a weekend racing class? Actually racing, and trailering it home?
2 options:
1: (What I did). Buy 38301-EL45B from parts.nissanusa.com . Use the 15% off coupon. You then have a spare diff to get you home. This option is cheaper than .....
2: Buy a Z1 LSD, 2 new stub axles, new cover, cooler, urethane bushings, and diff support brace. Have it built by someone who knows WTH they're doing (About 3-5 hrs labor).
I would bet the Z1 LSD is stronger than the stock performance one (Part # 38301-EL45B).
5thZ
Atlanta
2 options:
Thanks for the reply. No endurance racing or time attack. Just planning lots of track weekends doing HPDE. To your point the stock LSD might be more than capable. I'm coming from the 370Z Sport which has the VLSD which more or less started acting like an open diff when hot. After researching seems like it's not going to be the same problem here, but was curious if there was a better LSD than Nissan provided - without the drawbacks you laid out with the Z1 option.
Well, since you are in ATL, you could just drive to Z1. Just the shipping saving there would be like a 50% off coupon!
Which Z1 diff cover are you referring to?
Cant wait to hear more about this. Im still saving for one. When I get one, I will follow your process
5thZ
Atlanta
Unfortunately (or fortunately?) although the discount code worked it is a local pickup for me and it still is around $2,000 before tax. It's not an immediate need right now (need to do surgery to move 370 suspension components to the new Z). But will keep looking and update here if I decide to go factory or aftermarket. Another thread suggested looking at used on eBay or marketplace. Guess that couldn't hurt?
Hattori
Nissan Z sport, 2024 Nissan Z Nismo, S15 Spec R, Siliva K, 99 FD, soon an FB?
Data Analyst/Engineer
I believe you should get the Nismo 1.5 way GT LSD. I've equipped it in my Nissan Z sport 6 speed. There is minor chattering at low speeds, after 600 miles it's very quiet- occasionally lifting off at speeds it chatters but it's a nice noise. When it comes to cornering; it makes a world of difference, the power comes down with ease and the controlabillity is all there with the plus of being durable. Z1 has a video on it. Here is the Diff it's a direct swap: https://www.z1motorsports.com/nismo...2023-nissan-gt-mt-lsd-pro-15-way-p-36949.html . I have photos and videos as well let me know if you'd like to see them.
5thZ
Atlanta
That is a great suggestion! I was also leaning towards this but wasn't aware if anyone else had tried this yet. Do you have yours set to Low, Medium, or High? I might be referring to the Nismo 1.5 way GT LSD Pro. Do you have that one?
Hattori
Yes that's the correct one. My current setting is Medium it's perfect for windy roads and putting power down on stock 245, and I don't see a need for the high setting unless you are running semi-slicks or super sticky Dunlops. Low is also a great setting and give more than enough lock and feed back, but with the setting at medium cornering at speeds of 80+ tires have a very - almost torque vectoring esque pull, often times taking extremely sharp turns and putting power down I don't know what I would do without the Diff. There isn't a need for all the above with the Z1 as the earlier post had mentioned. Though if you were to track it I would worry about the temps of the diff fluid but it's minor since you'd be using 75w 140 Nismo oil which is Perfect, doesn't effect shifting even in extremely cold weather. High is a very capable setting but as the diff sorta "beat" my tires in terms of grip it was trying to achieve it was useless. Though with the new Z and based off of motorsports racing they use the High setting in the super taikyuu in which they made this one anyway, and they were dominating in cornering sections against the Supra. Do as you will lol.
