Idle relearn after CAI install?
Neutr0n
Alberta
AW11, 3IS250, RZ34, ST185
Do you all have done the idle relearn after installing the air intake? is there a way to do it without a scanner?
Nis Mo Z
Moses
Loganville, Georgia
service tech
I didn’t know such a thing was needed. I just drove the car after the intake install
I did not perform the idle relearn and it smoothed out nicely on its own. Even more so once RacBox fixed a small vacuum leak they discovered elsewhere when dyno tuning it.
Same here. Nothing special done, nor did I notice any changes/issues after install.
Didn't know about a relearn. I did disconnect the battery to avoid any issues by unplugging the MAF sensors. Not sure if that had any effect, or was even necessary.
Howdog70
Howard
Los Angeles
240Z
No issues installing and then removing Nismo CAI. Idle was perfect going both ways.
FatRatZ
I just removed the originals and put in the Nismo CAIs. Didn’t do anything special and didn’t notice any idle changes at all. Ran just fine.
Neutr0n
Neutr0n
Alberta
ok good to know. i did it once for a customer at the dealer for a 350z so i was wondering if it was same here.
thanks for all the input
