Considering a Z
Yes, the car had about 1200 miles on it before I put on a set of Z1 sway bars...I ordered them before I even picked up the car. I've had many Z's before including two 370Z's. I had ZERO doubt that I'd be unhappy with the amount of body roll on the stock Z34 chassis. The Z1's are good, but likely not better than the other usual aftermarket brands (I've had Whites, Eibachs, and Stillens over the years). On these Z1's, I set them up on the stiffer of the two holes. That did eliminate the body roll but also harshed up the ride a bit more than I wanted. I plan to reset to the softer hole when I get around to it.
Thanks for the input; very helpful. I'm planning on doing the same.
JonnyG
Jonathan
What is the common solve for Fuel Starvation. All I see is upgraded pumps - how about Pride Auto's
Fuel Pick up Kit - I've searched this forum and found not much chatter on it. Is it a real problem - I watched a recent You Tube comparison between Dark Horse, Nismo & Supra/M3 and it showed the Nismo starving down a full straight.
https://prideautollc.com/products/pride-fuel-pickup-kit
Anymore remedies for this? Important, not worrying about fuel levels at events!
  • Like
Reactions: D2M
I have a 2024 Performance Auto trans and do get the "lurch" at lights every so often. My 2022 Frontier did the same thing for the first couple thousand miles too. It has (the same?) 9-speed auto trans too. Hoping it goes away in the Z eventually too but I have heard people say they still have it after thousands of miles...
So I was just thinking about this the other day and you know what? I haven't had the "lurch" for a solid 3+ months now. Had my Z for over a year and 6k+ miles appears to be all but gone. I was hoping that would be the case and does seem to line up with what happened in my Frontier too.
