C/D Lightning Lap Data
jdrxb9
ND2
This is a bit dated, but I was thinking about how the Z might do on this next(?) year - https://www.caranddriver.com/features/a23319884/lightning-lap-times-historical-data/
See below for what I think are some relevant cars/times with ballpark prices.
While we'd obviously like to see the new Z right there with the Supra 3.0, and tire tech has come a long way since C/D tested a Z, that is a BIG gap from where the 370 is now.
I think as long as it can get ahead of the FWD'ers I'll be OK with it :)
YearMake & ModelTimePrice
min:secnewused (as of May '21)
2014​
Chevrolet Corvette Stingray (C7 Z51)2:53.8NA$40,000
2018​
Ford Mustang GT PP22:53.8NA$38,000
2010​
Chevrolet Corvette Grand Sport (C6)2:58.8NA$32,500
2021​
Toyota Supra 3.02:59.3$53,000$48,500
2019​
BMW M2 Competition2:59.7$55,000
2020​
Toyota Supra 3.0 Premium3:01.4NA$48,000
2016​
BMW M23:01.9NA$40,000
2016​
Ford Focus RS3:03.9NA$30,000
2018​
Honda Civic Type R3:03.9$38,000$32,000
2020​
Ford Mustang 2.3L HiPo3:04.4$39,000
2016​
Mazda MX-5 Miata Cup Car (~215/40 BFG slick)3:06.4
2019​
Hyundai Veloster N PP3:07.7$32,250$26,000
2021​
Toyota Supra 2.03:09.0$40,000
2009​
Nissan 370Z NISMO3:12.0NA
2006​
Nissan 350Z Track3:12.5NA
2018​
Subaru BRZ tS3:14.0
2019​
Mazda MX-5 Miata RF Club3:17.2
DevonK
Take a guess
TBD
My guess is it will come in around the CTR's time.
I have used dynos from the new engine (now in the Q60 Red Sport) to create a 370 with the new torque and power profile in Assetto Corsa and will run some AI laps at 100% ability on VIR for both engines to see what difference the power and torque changes make and report back. (I also added a 9 speed auto to another variant which should give the fastest time.)
I think in terms of suspension changes alone coming in the new Z and their impact on lap times that the improvements to be made will bring the standard car at least up to the level of the current Nismo, probably higher. Tires should be up at the current Nismo level as well.
DevonK
Take a guess
TBD
FWIW (which is isn't much) the Z with the Q60's VR30DDTT and a 9 sp auto was 6.1 seconds quicker around VIR than the current Nismo Z when going flat out (qualifying) with 100% AI ability and with semi-slicks on all cars. So if you subtract that 6 seconds from the Nismo's lap time above that would put a hypothetical 400Z on pace with the Miata Cup car. Not too impressive.
In Assetto Corsa the lap time of the current Nismo Z was about 6 seconds faster than the Nismo in the LL, much of that no doubt due to it not running street tires but semi-slicks; plus the 100% AI "racers" are probably a bit faster than the C&D journalists.
jdrxb9
jdrxb9
ND2
Well, if the engine alone is worth 6 sec., I'm still pretty hopeful.
The '09 was tested on Yok Advan Sports (https://www.caranddriver.com/features/a15387935/lightning-lap-2009/ - also note in here the Mustang arrived on the wrong tires and subsequently cut 5 seconds with the correct ones), a tire which was effectively replaced by the Advan Sport v105 shortly thereafter. The v105 is/was on par with the PSS (https://www.tirerack.com/tires/tests/testDisplay.jsp?ttid=174), but the PSS has been surpassed again by the PS4. (I can't find a quick head-to-head quickly, but here are two tests both vs the P Zero: https://www.tirerack.com/tires/tests/chartDisplay.jsp?ttid=218, https://www.tirerack.com/tires/tests/chartDisplay.jsp?ttid=223)
So hopefully Nissan will fit a tire 2 generations better than the last one tested and will hopefully use some of that big maw for brake cooling :). IF it gets both of those, some general chassis improvement, and a real LSD, the new Z could end up on par with the CTR, or even better.
DevonK
Take a guess
TBD
Getting a real LSD sounds very doubtful based on what I have read, the 400Z is in truth a major refresh with a new engine and skin rather than a new platform/chassis or even suspension, so the viscous LSD is likely to remain. As will the CSC on the MT. Hope I am wrong on both counts.
jdrxb9
jdrxb9
ND2
I haven't been following the history all that closely, but I haven't seen anything to really rule out a good LSD.
This post (#81) says development was "a few hundred million" and you can get a Quaife or Wavetrac to fit in the current housing - hopefully some of that millions went to a serious re-tuning of the springs/dampers/diff, which could be significant even if the geometry/hardware looks the same as current. I do agree it seems we're unlikely to see an all-new GM-style eLSD considering the Q50/60 are still on open diffs even in RS 400 trim.
Edit: Also, Nissan will get roasted in the motoring press if they bring the vLSD again, especially after the press harped on it for the past 10+ years and the (presumably significantly cheaper) Miata (club) and BRZ/86 (all!) both have Torsens.
Houston.RZ34
Texas, USA
Q70S 5.6 | Stingray Z51 HTC
COO
There's a ton of carryover from the Z34, I wouldn't be surprised if it's the same vLSD.
As for lap times....picture a 370Z Nismo w/ 400hp x 350tq, the Supra 3.0 is 382hp x 368tq....that's +18hp to the Z but +18tq to the Supra.....they would come out about even I'd think.
410hp x 475tq is possible stock on a VR30 tune only and still quite safe, I'm hoping Nissan tweaks the VR30s tune on the Z35 but I highly doubt it.
Trackaholic
2016 GT350, 2003 350Z (sold after 200,000 miles)
Now that some of the details are out, does anyone have updated thoughts?
Clutch-type diff, could be good if tuned well.
Sounds like the suspension setup was re-tuned, and somewhere I read that more caster was added (which will translate to more camber when when the wheel is turned without affecting breaking or tire wear on the street).
I'm also sure that new tires will greatly improve overall grip.
Big question for me is brake cooking (oops...typo...meant cooling). Will they be able to get the brakes to last more than a lap or two? At least it should be relatively easy to get a BBK if needed, due to sharing a platform with the 370. I had a Stoptech from BBK on my 350Z and loved it.
If tuned right, I see no reason the Z can't get right around 3:00. Big question is whether they've made the handling more responsive.
-T
jdrxb9
jdrxb9
ND2
Some videos up from this year's testing
https://www.caranddriver.com/videos/
notable:
2021 Mustang Mach 1 - crushes with a 2:52 - right with the GT350R, a bit ahead of SS 1LE, WAY ahead of 3.0 Supra, etc.
2022 Civic Type R LE - down to 3:01 (from non-LE 3:04) - really impressive for FWD, also slightly ahead of Supra :)
2022 Golf R - down to 3:04 (from 3:12!) - now where it 'should be' with Focus RS, TT RS, WRX STI, etc.
2022 GR86/BRZ 'twins' - down to 3:12 - good improvement and right with 370Z Nismo, but kind of in 'no man's land' vs 'modern' cars between the Miata and the 4 cyl. supra / quick FWD&AWD hatches
Now we get to wait a whole year to see what the Z can do... ?
94boosted
Tom
Camaro SS 1LE, BMW 340, Ford F150
You can't pay too much attention to Lightning Lap data unfortunately, in the C&D Lightning Lap the Mustang PP2 is a second faster than the SS 1LE, however it comes from the factory on Sport Cup 2's, which is a very aggressive track tire. When Throttle House put the 1LE on Sport Cup 2's instead of the OEM GY SC3's it was over a second faster than the PP2, on a much shorter track than VIR. It just goes to show how much it all comes down to tires. With the Z coming on Bridgestone Potenza S007's, which is a mediocre Max Performance Summer Tire, not even an Extreme Performance Summer Tire, let alone Sport Cup 2, it's not going to do well in the Lightning Lap sadly.
The 21' Supra being on Michelin PS4S's and having active suspension and an active diff, while being lighter and doing a 2:59.3, I'd be surprised if the Z could come within 2 seconds of that time at VIR.
jdrxb9
jdrxb9
ND2
Yes, you definitely have to pay attention to the tires and not sweat the small stuff (hence my smiley on the CTR vs Zupra), but I think LL is worth looking at to assess the general level of 'competitiveness' - at this point I'm not sure the Z will beat the Veloster N(!), let alone get within 2 sec of the 3.0 Supra ?
This was why I got the PP2, the entire package, susp tuning, 305 SC2s square, was very quick from the factory. Lightning Lap typically compares lap times on factory rubber, since those are what manufacturers design cars around. The new Z won’t come close with those S007s.
Also look at the Laguna Seca laptimes on fastestlaps.com
