Black Friday brake job!
Figured I'd take advantage of some Black Friday deals and tackle the brakes as a winter project!
  • Z1 2-piece rotors (front & rear)
  • Powerstop Z23 brake pads + 4 extra packets of brake grease (front & rear)
  • ATE TYP 200 brake fluid
Mainly looking to accomplish two things here, shed 30 pounds of rotational weight and get some decent stopping power out of this car. I think the drop in rotational weight should alleviate some of the stock shock floatiness since they'll have less weight to control, along with sharpening up the steering a bit. I suspect the calipers are fine, but these stock pads are garbage. Poor bite and quick to fade even on the street with any hint of aggressive pedal use. I've previously flushed the brakes & clutch with ATE TYP 200 DOT4 brake fluid and I intend to stick with the same. I had a bad/scary experience once with aftermarket braided SS brake lines so I'll be keeping the stock lines in place.
I opted for Powerstop pads after running them on both my Corvettes (C7 & C8). I went for the Z23 pads as they share the same compound with the Z26, but include a rubberized shim instead of stainless steel. As a street car that gets driven in temps down into the 30F's, I wanted to ensure they stay as quiet as possible. If I were still in Texas I would have gone for the Z26 since those shims are better for high-heat/temps. Again, the only difference between Z23 & Z26 are the shims.
Pictures to follow as parts arrive!
Z1 has shipped the rotors and RockAuto already shipped the pads/grease. Oddly enough, shipping from RockAuto was cheaper with the grease packets than without; never hurts to have some spares laying around. I'll get the brake fluid coming from Walmart when I'm ready to do the install so the 1L can is as fresh as possible.
SleepyD7
David
Gainesville Florida
2024 Manual Nissan Z Performance, 2013 Nissan Xterra, 2020 Lexus IS3050
Audio Video Integration Sales
Hell yeah! I know you’ve been considering this mod for awhile. Hopefully that -30lbs you get a noticeable difference in agility. Stopping power always nice too. Good info on the temp shims, I can’t stand squeaky brakes so common with aftermarket brakes.
Agreed! As soon as a mod decreases drivability or livability, I become very displeased with the car. Been down that route a few times (DSM, S2k, Evo IX, & C8)... I didn't do it on my Evo X or C7, and attempting to stay the course on the Z.
I ran Z26s on my C7 with the factory Z51 slotted rotors, and both the Z23s & Z26s on my C8 (stock Z51 blanks and Powerstop drilled/slotted). The C7's braking, stock or aftermarket, blew the C8's away. Brakes are one of the areas GM had to cost-cut on the C8 to hit their pricing targets, even with the Z51 package which was super lame and a big disappointment I had.
DBZinTN
David
Tennessee
Technical Sales
Nice discount on the rotors! Wonder how long that coating lasts, no rust after sitting wet sounds nice,
I had Centric rotors with a similar coating on my Evo IX and no issues with it, even after driving through a salty Minnesota winter.
RHE2026
2026 Heritage Edition
Thanks for listing the links. Yep definitely noticed the stock shocks could have been tweaked to be a bit firmer for better handling for sure. A nice feature that Nissan could have had added is a ride control for sport/performance. I like the sound of 30lbs lighter I’m sure you will notice that in the handling and stopping.
phil_chronicles
Loved Centric Rotors. Sad PowerStop had to go out of business 😥
Since you mentioned SS, and if you dont mind me asking, what -neg experience did you have? Was it for daily or track? I have CZP SS in my cart and wondering if I should get them 🤔
Powerstop is still in business, but Centric/StopTech aren't.
I was braking hard from 80 MPH on Dallas North Tollway in my Evo IX GSR and the front driver's line burst. I lost pedal pressure and it sprayed brake fluid everywhere.
*EDIT*
They were Technafit brand actually...same that CZP is selling... For brake lines, I'll be sticking with OEM that I know has gone through rigorous safety testing.
phil_chronicles
Shouldve googled before inserting foot in mouth. Meant StopTech 🙄
SS shouldnt have bursted. What a mess it mustve made.
Figured so, all good! I liked StopTech and Centric as well, ran a bunch of their parts!
SS brake lines are typically just rubber lines with a SS sheath and sometimes also a plastic sheath around them, and will only be as good as the weakest link. The weakest link is ypically the joints/fittings. I knew a few Evo guys that had a simlar experience across multiple brands. DOT-compliant is important to look for when it comes to brake lines, but not the end-all-be-all since that's a self-certification.
aurora rz34
Brock
Pennsylvania
2026 nisaan z heritage edtion
Gotta get z26 getting just z23 feels like a disservice to all the other mods
Z1's shipping is as quick as it gets! Pads should arrive Tuesday.
jacksonmagnet
ny
z
What number have you gotten to on g-force gauge, acceleration and deceleration?
