AT vs MT rear differential differences?
Mugzilla
Short Hills, NJ
2024 Z Sport (MT)
printer repair man
I swear I used the search function.
Before I order a Z1 LSD for my 2024 Sport, I have a question:
What is the difference between the LSD from a Z Performance AT and a Z performance MT? If I recall correctly, it is the gear ratio. Anyone know the ratios?
D2M
NJ
Nismo Z, Veloster N, Ram 2500
AT is 3.133
MT is 3.538
I would like to try a MT 3.538 in my Nismo at some point if I can find a cheap used one.
VR30Z6spd
Sultan
KSA
Z 6spd
AT is 3.133
MT is 3.538
with your 9speed it will shift too soon, with much more added power i will swap for AT on my MT car
Mugzilla
Mugzilla
Short Hills, NJ
2024 Z Sport (MT)
printer repair man
That would give you a higher top speed, correct?
Have you dynoed after adding the power adders? Do you make more power now at higher RPMs?
VR30Z6spd
Sultan
KSA
Z 6spd
yes i have tuned my car, most power is made between 2500 to 5500 rpms
top end will not increase much as the stock turbo efficiency is not great
stock top end was around 360-rwhp
full bolt ons top end was around 420-430 mid range the gain is over 100 hp and 120 torque
Mugzilla
Mugzilla
Short Hills, NJ
2024 Z Sport (MT)
printer repair man
OK, here's the REAL question:
In what other cars did Nissan use the LSD rear end from a Performance Z? Looking to do a swap from my one-wheel-peel Sport to a LSD.
