Aluminum Oil Pans (Z1 vs. CZP)
Fulshear, TX
VP
I'll be doing the Mishimoto panel with Dorman aluminum oil pan.
Fulshear, TX
VP
Dorman 264-864 aluminum oil pan has arrived; includes the gasket and a magnetic drain plug:
Not bad for $158 from Walmart.com!
Fulshear, TX
VP
Let me know if it fits.
I don't have the Mishimoto panel yet, but the Dorman oil pan dimensions are identical to the OEM plastic pan. If something fits with the stock pan, it'll fit with the Dorman.
el mágico
I've got the reverse problem. I have the Mishimoto shroud, but no aluminum pan.
Fulshear, TX
VP
el mágico
Fulshear, TX
VP
Fulshear, TX
VP
It's rated at +0.2 qt and 6.5 qt complete drain.
el mágico
I was interested in the high oil capacity in the other pans available. Then I saw the price for the one you listed. Made sense.
Fulshear, TX
VP
Yup, OEM replacement, no real need for more than 6.5 qts with adequate cooling capacity. The cast aluminum will dissipate heat more effectively than composite/plastic which acts as an insulator.
traska_rz34
traska_rz34
Liam
Cocoa Beach, FL
Order this one up, you won't be disappointed! Quality gasket, perfect fitment, magnetic drain plug, and best of all aluminum not plastic.
https://www.walmart.com/ip/Dorman-2...ific-Infiniti-Nissan-Models-Silver/5343664142
This is a great find and way cheaper than others are selling it for. Question - I see the listing says it relocates the drain plug. Is it still in a place that the service door on a shroud will be able to access?
