2023 Nissan Z Tyre pressure
Madgud
Nissan Z Proto (Manual)
Hi everyone,
I was wondering what tyre pressure you guys run at on the 2023 Nissan Z. The manufacturer's recommendations seems quite low to me. I used to run at 40-42psi on previous cars like the Nissan S15 for example.
Perhaps there's a reason for the new Z to have lower tyre pressure. Not sure.
ceric
CA
'16 Mazda6
Tire pressure PSI.
PSI * sum(contact_patch_areas) = vehicle weight.
If the tires are wider (i.e. bigger patch area), PSI usually gets lower. The new Z has pretty wide tires.
Owners can adjust PSI to fit their needs.
I usually fill to one PSI over, and then fill again when it gets down to the recommended pressure. It's not much, but it prevents the tires from ever being low.
I love the tire pressure display in the Z. My G37 had TPMS as well, but only a binary "it's low* signal. The Z's display is often on my dashboard.
Dot’s son
Titan
Louisville
The dealer has my rear tires inflated to 35 PSI and it seems like too much as the rear slides out fairly easy. I am going to lower mine to about 30 and see what it feels like.
Raven1
Phoenix
2007 350z HR Motor
503rd Lead Farmer
32 Front / 29 Rear - in the official Nissan video - looks like a yellow proto z - 19" tires - pause video @ 25 second mark.
Tire size / vehicle weight dictates tire pressure . . .
Spartan
Dubai
2026 Toyota Corolla GLI 1.6L
Sales Executive
thanks for this video, I used to inflate tires after they have warmed up not when they're cold so when they aare cold they would always show 1-2 PSI less. I will inflate them now when they're cold.
Spartan
Dubai
Sales Executive
No it feels similar to air filled tires. I wouldn't fill with nirto again. If the tire goes under pressure i cannot find anywhere to refill it and the dealer is about an hour away from me
I used to fill mine with Nitrogen but also stopped for the same reason. Topping them up is a pain in the butt.
Speaking of topping up, I bought this portable tire inflator a couple of days ago, works like a charm and now I don't need to drive up to the gas station or tire shop to top up my tires. Also nice to have for emergencies even though it's slow, it can at least get you going if you were in a situation where you tire pressure was very low. You have to inflate the tyres with +3 PSI from the tire pressure that appears on the device VS what's shown in the car, tested on a BMW X3 and my Z, both needed 3 more PSI but all good.
UGREEN Portable Air Compressor
SHUGGAR
Las Vegas, NV
2024 Nissan Z, Performance, 6MT
Purchased my 2024 performance in late August. All tire pressures upon deliver we set at 37 psi. I adjusted them to 33 psi. Just had my first oil change today at 2000 miles, tire pressures are back to 37 psi. from the dealer. Tires are reaching 40 psi during my normal commute to work. Too High??? Why are they not following the recommended pressure?
MacCool
central Minnesota
2024 Performance Z
Hi everyone,
Why would you assume that Nissan wouldn't know the best tire pressures to run on the OEM tires?
MacCool
central Minnesota
2024 Performance Z
I always had the same problem at my Nissan dealer. They always want to check tire pressures as part of their "57-point courtesy inspection" during an oil change (they always want to rotate the tires as well).
Just the other day I had my oil changed at a local performance shop. They were very clear that the mfgr-recommended tire pressures are appropriate for the asymmetrical Potenza OEM tires, although they were not big fans of those particular tires, and I agree.
I run the pressure recommended by the sticker at the driver's B pillar.
I also noticed that anyone who services the car will return the car to me with overinflated tires. No idea why. Been happening for years on multiple cars at multiple mechanics. I just shrug and fix it.
