Z Tacho red line.
Stefanovich
steve
Australia Victoria
2023 Proto Z M/T
retired mechanic
Hi Z fam, can anyone explain why the Z Tacho red line starts at 7k and goes to 8.5k but the engine is rev limited to around 6.8k?
Koryak
John
Colorado
retired telecom instructor
Keep in mind the tach is showing a graphic representation of what the digital electronics are doing. Nissan likely sets the rev-limiter conservatively and may be adjusting for gearing and rate of RPM increase, like lower in lower gears.
Having a range of over-rev like to 8.5k is just old school tradition. Hopefully nobody ever sees this unless the ECU is tuned or they botch a 6 speed manual down shift. The Z's stock bucket followers and camshafts are optimized for max HP slightly below red line.
Most vehicles I've owned have the indicated redline a few hundred revs higher than the fuel cut.
Sometimes automatic transmission programming will shift even sooner than the fuel cut, can't have the automatic shifting too close to fuel cut.....
