Short throw shifter
Cujo2811
Cujo2811
Joe
2024 Nissan Z Performance 6MT
I guess I'm in for some fun! What's worse, getting this thing off, or the lower passenger side intake clamp?
john mac
John
denver Nc
2026 nissan Z performance
sales
Regarding knob removal, I recently installed a Billetworkzx Chunk knob. I removed the OE knob without damaging it or the shifter by using two strap wrenches and a hair dryer to heat and loosen the Loctite.
I don’t know what happened ! The loctite guy must have been at lunch when my car was coming down the line… I finished installing the nismo ignition switch and just for fun tried unscrewing the shift knob and presto came right off! No signs of thread lock anywhere! Installed a 370z limited edition knob fit perfectly.
Schantin
www.youtube.com
2026 Nissan Z; 2002 Camaro Z28
ER Nurse
It's not fun taking the stock knob off. I made a vid (see below). It only deals with the knob replacement, not the entire shifter. If you start at 2:35 it will give an idea how stubborn the stock shift knob can be. I used 2x vise grips + grippy material to remove mine.
Cujo2811
Cujo2811
Joe
Awesome video. Appreciate you sir. I will be giving this a go this weekend as well as the Z1 short shift kit!
Brandon, Fl.
Wow!
You locked out! no pun intended... šŸ˜†
Michael C.
Michael
Everett
Desk Jockey
@CPerdomo beat me to my response. @john mac is one locky guy! =)
bj2348
Centerville
1972 240z, 2024 Z Heritage
I found a video on Youtube where a guy used cut up bicycle tube and a large box end wrench to remove his. He stretched the tube and wrapped the stock know tightly and then lashed the wrench. He got his stock knob off without damaging it. I am doing the same thing with a pair of cheap amazon 22" mountain bike tires. It is slow going but it is working, I have had to unwrap and rewrap a few times, and the straps do sometimes split, so have 2 tires cut up into about 1" wide strips helps.
Cujo2811
Cujo2811
Joe
Got it all installed. Thanks for all the insight fellas!
1 question, after realigning the plate with the reverse lockout, i feel if i was to shift all the way over to 5th, i can push the shifter to the right of 5th gear. Like into a dead zone. I don't recall that being there before. I have the plate position with the arrow to the right and the lockout raised. The ball and socket are aligned onto the spring with the provided spacers. Everything done to spec.
Maybe this "area to the right of 5th" always existed? I don't know. It's not hurting anything, all the gears feel much tighter with better throw. The only thing I see is I could miss a shift to 5th i guess?
Can anyone verify if they have the same? Or if you are still stock, is that the same? I hope I am explaining this correctly.
