Looking for a VR30 oil pump control solenoid (Nissan pn 15031-BV82A)
ā€˜24 Z NISMO
This thread has morphed from looking for a solenoid, but not sure what to do. May ultimately have helpful info, no clue.
Anyway, I got the solenoid. Full of glitter. Also, looking at it under a scope it looks like it was dropped and the end (ring around the screen) is cracked from the OD to the ID. This is why I don't trust ebay for used stuff.
Ohm'd the pins and it's coming back with 24.4-24.5 ohms. No clue if that means you can slap a 24.5 ohm resistor (or 25, idk) on the end of the harness to avoid lights.
Where my nerds at?
Helpful nerds. Not the type I work with. If I needed Dungeons and Dragons advise *advice* I'd be swimming in info right now.
dogunbound
Shane
Houston, TX
Software Engineer
Bro you got a nissan scan tool thingy? maybe try unplugging it and then putting a 25 ohm resistor in. If it throws codes just reset it.
ā€˜24 Z NISMO
I have an Innova scan tool.
If that does throw a code, it’s one I could erase?
I know from experience my tool won’t erase airbag codes (took the seats out of a Z33 for a thorough cleaning without disconnecting the battery).
Make sure you use a high watt resistor; it's almost 10 watts at 14.5v.
The plug is the hard thing to find for me to make a simple bypass.
ā€˜24 Z NISMO
20W, 50W, 100W?
I feel like a higher wattage doesn’t change anything other than how much the res can handle, but not sure if there’s an ā€˜overkill’ point.
Typically deal with axial. Would a TO220 package work? (25 Ohm, ?W, 1%, TO220)
dogunbound
Shane
Houston, TX
Software Engineer
Try reddit.com/r/askcarguys šŸ˜…
There might be someone who has defeated some nissan sensor at some point.
20W, 50W, 100W?
Anything More than 10 watts, though I'd go slightly higher because it's in the hot engine bay.
15-20w is probably fine. You are correct the wattage just makes sure the resistor can handle the heat and not burn up/melt.
The TO220 may work depending on model and size of heatsink (no heatsink appears to be ~1 watt for most I'm seeing)
