Launch/Pull Tips
CaliforniaZ
24 Performance Z
What are your best ways to launch or do pulls? For people with 6 speed manual, Any tips on getting the best 0-60 time from a stop? ?
Sold the Z
1. Be safe.
2. Don't let the tires break free. A chirp or two is fine, but if the wheels spin, you're going sideways instead of forward.
3. Shift once. Remember 60 is the top speed for second gear. ?
MattJ2020
WA
2024 Z
Photographer
With the Auto, you can pull out quick and can be controlled. Really need better tyres to test out going flat out from the start! Hah
malaphasis
Wisconsin
www.artstation.com
Z, 350z, 300zxTT
video games
I can't even get my auto to go into launch control. I've read almost everything on it, can't activate launch control in the automatic...
D2M
Nismo Z, Veloster N, Ram 2500
Mine work every time like clockwork. Make sure the trans is up to temp and you are pressing the break pedal down REALLY hard.
MattJ2020
WA
2024 Z
Photographer
There is a Launch Control in Auto?
malaphasis
Wisconsin
www.artstation.com
Z, 350z, 300zxTT
video games
DM2: For automatic ?
D2M
Yeah.. Make sure engine and trans is fully up to temp, TC off, hold both paddles in, press brake pedal VERY hard and floor it, release the brake and enjoy the ride. Works for me every single time..
D2M
ok - I'll try again in spring.
Does it let you roast tires? or just grab right away?
When using launch control its a smooth start from a stop but once it hits 2nd it will spin a little then hook up and a slight spin in 3rd. Works pretty consistently.
If I want to roast the tires I will just punch it %100 from a stop, it spins through 1st it will also spin 2nd, 3rd and partially 4th leaving a nice smoke show. This is in sport+ mode, the shifts are straight violent.
D2M
I tend to do this at least once per drive. This Z is the a tire shredder. Here are my rears with exactly 5000 miles on them, fronts still look like new. I have a brand new set staged ready to go on in the spring for more fun times..
MattJ2020
WA
2024 Z
Photographer
Reminds me that I should check my rears but it is hot and humid here in Australia from November right through to March/April, at the moment it’s averaging 36°C right up to 40° meaning around the mid 90°F hah!
