How do I fix the fuel starve issue?
phil_chronicles
Hoping the Nismo baffle is a separate piece for the fuel pump. And is interchangeable to fit on the Sports/Performance fuel pump 🤞🏽🤞🏽
BMW e46 M3 had a fuel pump baffle that was a separate part that fit on any e46 3 series fuel pump. Saved $$$ on buying a new pump
captahole
2024 Z heritage edition, NSX
Now that the 27 nismo has apparently fixed the issue with a new design anyone know of the price and if it’s backward compatible?
Crownleyian
Nelson
I.T.
Seems like the fuel starvation fix is bolted into the tank, not sure these will be available for previous owners and no I don’t want to go 3rd party to void warranty. I have seen another video and i sear the drilled holes are in the tank already, put a video and photo of it, the last 2 are a AMS installation but on the bottom right I see what appears to be a pre drilled bolt hole, if this is even the same side.
I dunno probably someone with more knowledge can enlighten us…
nissimo1983
Simon
indiana
2027 nissan z nissimo
engineer
Possibly an OEM solution on the horizon? Supposedly Nissan addressed this issue in the 2027 model and could be retrofitted to older models probably. Not sure if it would be any cheaper or easier than current aftermarket solutions though.
On my 27 Nismo MT, at 3k I only experienced the issue once but even the sensors around the bumpers failed. At 5k I have no issues anymore. I love the ride.
This is A+ investigation, thank you!
captahole
Spoke with my local dealership and got a quote to replace my '24 tank with the new '27 tank. See attached. Also have a case with Nissan Customer service to see if I can get it covered by them.
Midz10
Saudi Arabia
$4,292.85 :oops:
That's a lot of money. There are already cheaper fixes for this issue. Both the Holley HydraMat fix and AMS fuel basket fix are less than 1/4 of that quote.
jacksonmagnet
ny
z
I haven’t had a fuel starve issue, I drive pretty hard, usually keep it above 1/2 tank tho
captahole
you most certainly will on the track. I have not had any issues on the street.
jacksonmagnet
ny
z
What kinda g force on track are you seeing, I’m frequently at .9g on all axis
captahole
1.1 - 1.3 using pilot sport for S’s. The issue is sustained G’s and elevation changes.
dogunbound
dogunbound
Shane
Houston, TX
Software Engineer
1.5G on track at COTA's carousal. Gs are dependent on the tires, not the car.
At 1.5Gs, anything less than 2/3rds of a tank, and you'll get fuel starve on right handers.
