Hard Wire Radar Detector/Camera in about 15 minutes
RadzShadow
New Mexico
ISSE
R3 and I am blind as hell up close. But I am anal when I install anything. The details matter. I only used velcro, not the wire ties. I am happy with the install, but I want to put a bracket on too.
So, what the pictures cannot really show. For the 3 wire install, the green wire closest to the drivers side is the IGN/ON to make is work. The always on is closest to the passenger side. From what I can see, visually, is there is zero difference between the two green wires. There may be a black/green on the passenger side, but the drivers side is the IGN/ON.
I hope this helps someone else on their install.
RadzShadow
New Mexico
ISSE
The blendmount is on the way. I hate the suction cups. Living in the desert ... anything rubber melts or rots away within a year.
I don't ever ... ever, ever ... tell the wife what I spend on this car. :lipssealed:
RadzShadow
New Mexico
ISSE
The mount arrived. The parts are small and I have neuropathy, so it will take me sometime and a bit of pain to install. Not Blendmounts issue, just mine. The quality of the mount is great! I just need to get 'r done.
RadzShadow
New Mexico
ISSE
After 4 months, I found the time to install.
https://photos.app.goo.gl/rLp7DGcchjCYKZp79
I apologize in advance if the pictures are blurry, but ... getting old sucks!
Happy I have no suction cups on my windsheild!
nismo95tt
TRS
RZ34, Z32TT
Looks good like go pro design-ish but not sure it will fit the Z and they do not list r series uniden detectors or nissan Z.
I run Blendmount on the rv mirror - they list car and detector model for fitment. For windshield mount i use the ebay $10 ”permanent“ mount - you can tuck your detector high and tight - out of sight.
https://ebay.us/m/erZBWW
nismo95tt
TRS
RZ34, Z32TT
For BF/CM, I bought an top end Uniden R8W, a Dongar DCA-10A mirror power adapter [https://dongar.tech/products/dca-10a], a Stealth Mount [https://stealth-mount.com/], a USB-C to RJ-11 power adapter cable [https://www.amazon.com/dp/B0D5B3667F?ref_=pe_125775000_1044873430_t_fed_asin_title&th=1] and a "tried and true" Blend Mount BR7-2001R [https://blendmount.com/aluminum-radar-detector-mount-for-uniden-r7-r8-r8w-standard-2001r-series-br7-2001r/?searchid=0&search_query="BR7-2001R"], just in case the Stealth Mount doesn't work out. I really hope it does, b/c I like the idea of one handed attach/detach as I'll probably be doing that at least 1-2x daily.
Will report back after all the parts arrive and I complete the installation!
RadzShadow
New Mexico
ISSE
I don't
Thanks for these pics, they were helpful!
With the Blendmount ... the R3 picks up the signals miles away now. Clean install and love it.
nismo95tt
TRS
RZ34, Z32TT
I don't
I'm excited to get Uniden and complete the install. I've been thinking about it ever since I got the car about 5 months ago (b/c it's fast, it's red, and it's my daily driver), and I just bought a loud exhaust too (AWE Track)...idk how loud it's going to be in person...I need some countermeasures!
RadzShadow
New Mexico
ISSE
I still have stock everything for the most part ... I hit 115 mph on my daily drive ... mad that asshats wouldn't get out of my way :LOL:
RadzShadow
New Mexico
ISSE
Best investment after buying the Z ... radar detector and a mount for it. Place it has high as you can and put the right foot to the floor.
Drive it like you stole it.
💓 this car.
nismo95tt
TRS
RZ34, Z32TT
Thank you so much. Super helpful info! Cleaned up / finished my Uniden R8w install today! I used your tips re: Driver's side green wire (and a multimeter to test ;)
I was using Dongar previously for power, but swapped it out for this: https://www.amazon.com/dp/B082V1245P?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_2&th=1
Had too much bulk with the Dongar, the wires, and adapters...my revised install is much, much cleaner.
Using this https://stealth-mount.com/ and pretty happy with it so far. When I had a minor issue with loose fit, and the seller's customer service was super responsive and quick to fix it as well.
Clean install, and easy to attach/detach without having to remove the RJ11. Looking at getting another for my other Z...
tractng
Los Angeles
2022 Miata, 2009 BMW X5
Infrastructure Manager
Do you guys remove the radar after use or only in some not in so safe areas?
