Hands Up all the Aussies
Supremekai
I am using the ROOM LAMP for constant power and POWER SOCKET for ACC power. The +/- sides are shown in the pictures.
There are 2 spare slots. The one above TCU is constant, but I can’t plug in a fuse tap as the Transport Mode switch gets in the way?. The one below POWER SOCKET has no power even the car is turned on.?
How did you hide the wires? I'm stuck at the A pillar ?
and where did you put the ground wire?
peter
Peter
2023 Z, Qashqai
Metallurgist
I'm guessing that was on sale, but would still love a link?
As black Friday is comming up in the US good time to buy, that's when I most of my stuff, most of the US nissan dealers will have an online parts dep, join their VIP programme for bigger discounts.
The biggest problem is shipping, I set up a US address a while ago and used this, all up was a lot cheaper than buying in OZ, but our dollar has since dived.
peter
Peter
2023 Z, Qashqai
Metallurgist
Mud
Brisbane
GUZ
Brisbane
I hid the wires with the airbag. The ground wire is attached to somewhere near the hood handle.
Supremekai
I got the a piller off and routed the wires under it.
I don't see the metal part where you have your ground. I'm trying to take the fuse box trim off but don't know how to remove the plastic fastener above the dead pedal... So I can find/use a ground point behind the trim
Edit: finally installed. I used a plier to stick it between 2 of the 4 holes and twist counter clockwise and it came out.
peter
Peter
2023 Z, Qashqai
Metallurgist
Fitted front and rear sway bars with new front and rear endlinks from Whiteline yesterday, haven't had a chance to drive yet to see the difference.
Got them through Fulcrum Suspension on a black Friday click and fit offer
MattJ2020
WA
2024 Z
Photographer
Pick mine up this Friday
Same color as mine! Love it… but I’ve got the black interior.
On another note, does anyone know how I could remove (in this example) the red interior parts that are red along the dashboard and gearbox area? Want them reupholstered in alcantara ?
Mud
Brisbane
I call these the knee pads, but I think they're referred to as "Console Finishers"
Steps 19 - 30 in this should get them off.
https://www.nissanzclub.com/forum/attachments/mc-10226134-0001-pdf.16297/
I don't think 19 - 24 are required, I don't think you need to remove the console / cup holder assembly. Pretty sure just removing the gear shift surround will be enough to give you access to the screws on the console finishers
Mud
Brisbane
I bought the Ottocast A2Air and Andriod Auto works great wirelessly, also paired it up with a wireless phone charger that fits in perfectly next to the USB outlets.
Hey @peter
Does this fit in the slot above the USBs? Got a pic of your set up?
