Heavy Dupree
Tampa, Fl
very curious to see how the automatic holds up in competitive racing.
Also curious to see if the mounting tabs on the Nismo sway bars hold up
Murix
SF Bay Area
I wish we knew the spring rate of the Nismo Z and the Nismo coilovers
sdktheway
Scott
Western NC
Nissan Z Nismo, Subaru Ascent
any insight into why they chose 0W-30 engine oil for this build?
heritageownerKurosawaz400
Hattori
Network/Cloud Engineer
Cold clearances are the same almost always, if you push more power or abuse the car more the oil weight will only matter more in that hotter range, since the VR30 is also quite tight cold 0W is completely fine, though hot 0w20 is only effective until around 226-230 while W30 is 250~; essentially clearances and lubrication change when the engine is hot, not as much when cold, when cold it’s still very tight and needs fast and easy flow.
