Fluid Temps
adamste19
Tim
Frisco, Texas
2026 Nissan Z
I just sold my 2018 Nismo 370z and bought a 2026 Z Performance.
At the track, the 370z always ran hot even with oil and transmission coolers. I added a supercharger and the transmission failed, installed a VR30 transmission but it didn’t sync up.
I’m in North Texas, but avoided the track from late May to mid-September.
Are the fluid temps on the 23+ Z similar at the track?
chadgigachad
'24 Nismo, also in North Texas. I went last year in March in early march at MSR Cresson. No temp issues were had. Had a bit of minor brake fade, but have since gone with stainless steel brake lines + high temp brake fluid.
TexasZee
Weak points for the Performance seem to be the Oil cooler, Brake Fluid, Brake pads, and Heat Exchanger. Some people report no issues stock - It all depends on what kind of track day you're doing and how long its being pushed.
The Nismo has two turbo heat exchangers (central and passenger-side), plus an extra engine coolant radiator. This gives it better cooling out the box than the Sport/Perf.
Best of luck. Great car.
Nis Mo Z
Moses
Loganville, Georgia
service tech
Where did you get your SS brake lines from? I'm trying to find out if the Z1 SS brake lines work on the Nismo. If not then I need to sell them
SavedByFaith_
Stephen
2024 Z Nismo
I got the Project MU SS lines, they fit my NISMO without issues
SavedByFaith_
Stephen
2024 Z Nismo
All Akebonos, when I was purchasing, said just the sport/perf model for RZ34 (well, the japanese equivalent trim name), but when I got in contact with Nengun, they confirmed that it would work for the NISMO
Nis Mo Z
Moses
Loganville, Georgia
service tech
All Akebonos, when I was purchasing, said just the sport/perf model for RX34 (well, the japanese equivalent trim name), but when I got in contact with Nengun, they confirmed that it would work for the NISMO
Thank you!! The Z1 SS lines said Sport/Performance as well so they should work.
