Duckbill doesn’t fit the way I hoped 😡
Maximus
Delaware
2023 Nissan Z
New duckbill spoiler fitment isn’t what I wanted and I’m not sure how to mount it.
My initial thoughts were to use double sided tape with a liquid adhesive to help the tape stick even better to the spoiler itself. But after test fitting it today, there seems to be a decent-sized gap.
Can heat the spoiler itself so that it flexes and I’m able to bend it to the contour of the trunk? Or do I use the self tapping fasteners to mount it and they’ll pull the gap closed?
Thanks,
Jah_Happy
Do you have pictures by chance? It'll also depend on the material of the spoiler. Some materials don't leave you much wiggle room without getting into some full on body work.
I had these fears and ultimately it's what lead me to Seibon because it bolted on using the factory holes.
Maximus
Maximus
Delaware
2023 Nissan Z
I’m gonna try to heat it with a heat gun and hopefully it becomes flexible. I’ll take a pic of the gap tomorrow when there’s more light.
Racebox
Diamond Sponsor
Racebox
goracebox.com
2023 Nissan Z
Tuning/ parts installation
We've been fortunate to have a great fitment experience with Southbay Autoworkz' rear carbon duckbill for the Z. Carbon pieces are always iffy when it comes to fitment. This sits nicely if you're looking for an alternative and should be out for sale soon if it isn't already! We stuck ours on with 60lb gorilla tape in a rush for Coffee and Cars, but it's held up wonderfully.
Maximus
Maximus
Delaware
2023 Nissan Z
If you could help me in letting me know where you put your tape…..
The Rocket Bunny one I have has an outer lip around the bottom of the spoiler and then it’s sunken in around the middle (not sure if you can tell by the pic). Did your duckbill have a similar “lip” and if so, is that where you put your tape….or did you put it on the inner area? Because I also have double sided tape and adhesion promoter
Thanks,
Racebox
Diamond Sponsor
Racebox
goracebox.com
2023 Nissan Z
Thanks,
Hey Chris!
Our duckbill did not have lips like this, though it did have the mounting holes like yours does. Personally, the tape that we used for installation was thick enough that even a lip like that shouldn't be an issue. We lined the entire perimeter with tape as close as we could get to the edge without it showing and then put a few strips in the middle as well for security. No issues so far, just make sure to use heat if you go to remove it later so that you don't hurt the paint pulling it off!
Maximus
Maximus
Delaware
2023 Nissan Z
Hey Chris!
Thanks for the insight ?? I think I’ll run the tape around the perimeter like you did and infill the middle with whatever I have leftover. Definitely have alcohol on hand to clean the surfaces before applying the adhesion promoter.
I just added spacers to widen the stance for this duckbill so it fits the look better being this is a non wide body.
DerrellSC
Derrell
South Carolina
Teacher
Looking for this spoiler. Can't find it on their website. Do you have a link?
Racebox
Diamond Sponsor
Racebox
goracebox.com
2023 Nissan Z
Did you use alcohol on the trunk itself to clean it….or will that damage the paint?
While we would never tell anyone that alcohol is good for paint, it is the best way to clean an area for adhesive installs- just use it in moderation and you'll be fine!
Racebox
Diamond Sponsor
Racebox
goracebox.com
2023 Nissan Z
Hit them up @southbay_autoworkz on Instagram, surely someone can help you get your hands on one! They weren't released yet when we got ours, so they may still be up and coming!
5thZ
Greenville, SC
QUOTE="Racebox, post: 68852, member: 3038"]
[/QUOTE]
Racebox over here being all helpful and stuff ?
