Coilovers and Wheel Spacers
C5y2kvet
Richard
Georgia
2026 400Z
Will tires rub if I install 20mm & 25 mm wheels spacers and lower the ride height 1” with coilovers?
frankydoodle666
sam
Vancouver, Canada
2027 Nissan Z performance
I’m lowered 1.25” with 25mm spacers with no problems.
Hi there, did you have to change out the control arms for adjustable ones? I’m considering getting swift lowering springs which drop the car about 1 inch. Wondering if I can just get the springs or if I need all the additional hardware to achieve decent alignment. Thanks
Not even with coilovers unless you excessively lower the car. The front uppers are not adjustable but you should still be at less than 2* negative camber up front. The rear should be able to be pulled into spec with the factory setup.
