Brake fluid bleeding
Stefanovich
steve
Australia Victoria
2023 Proto Z M/T
retired mechanic
Hi guy’s, l want to bleed and replace brake fluid in my 23’ Z. I’m an old school mechanic, well retired. I have read something about the ABS module complicating things when bleeding. Can anyone elaborate on this issue. Has anyone bled their brakes at home without issue? Feed back much appreciate.
Hi guy’s, l want to bleed and replace brake fluid in my 23’ Z. I’m an old school mechanic, well retire. I have read something about the ABS module complicating things when bleeding. Can anyone elaborate on this issue. Has anyone bled their brakes at home without issue? Feed back much appreciate.
Bled my brakes after doing a ss braided brake line install, have not run into that issue
Old school method is all you need; plan to use about 1L of DOT4 fluid. Just did my 2023 over Christmas. Make sure to do your clutch as well (if applicable).
Afaik so long as you don't empty the ABS pump itself it's flow through and doesn't cause issues bleeding. If you do change or empty the pump itself I think you just have to run the pump with a service tool/ the dealer and then bleed again after. I've HEARD some people take the car to a gravel road and do a bunch of panic stops to run the pump and then do the final bleed.
None of that is necessary though if you aren't changing the pump itself.
