Boosted 6 Intake install
jacksonmagnet
ny
z
Hands down one of the most beautiful rz34s I’ve seen, and respectful owners on this forum, and that’s your input? I’ll happily replace his washer fluid cap when they make one, if you show us your Z 🤷‍♂️
They already make one
Nis Mo Z
Moses
Loganville, Georgia
service tech
no one is concerned about the intake sucking hot underhood air ?
If you have an upgraded heat exchanger it’s a lot less of a worry because what dictates horsepower production is the charge air temps (CAT)more so than intake air temps(IAT). Now because the standard heat exchanger is way too small it’s more of a problem because the CAT’s were likely going to be horrible prior to the open intakes. I have the CZP H/X which is 3.2x the capacity of the OEM H/X.
Shumax
Curt
Wooster, Ohio
2027 Nissan NISMO Z, manual
Sales
I had Z1 carbon fiber intakes installed on my NISMO ‘27 and wish I could hear the turbo spool/“pssssh” noises. What would I need to do to accomplish that?
K&N intakes
Perfect hybrid design
jacksonmagnet
ny
z
K&N intakes
Yea, I have the k&n CAI, they will make turbo noises, they are in a open top box with gasket against hood(or very close), the oem tube through grille for stock intake didn’t match up 100% to k&n box inlet, could bother some people
