Bluetooth media lag/cutout
Horso
Brandon
Curious If anyone else is having this issue when trying to listen to music through Bluetooth from your phone in your Z, and getting constant lag or cutting out of songs constantly. It's so bad now I can't even use the Bluetooth for music, only the Sirius or FM, which doesn't have the issue. Bluetooth audio works fine with my same phone on other vehicles too, just seems to be the Z. I've tried unpairing and repairing, checking for system updates on the system itself but no prevail.
24 Performance, I’ve never had any issue with wireless Apple car play.
Horso I see you are in Canada,
It's important to note that the Canadian infotainment is the 8" system on the Performance model not the 9" system that the USA and other countries get for the Performance model. It may be the same as the US Sport model system though? Which is an 8".
I think @bpeckham was trying to keep a running list of at least the software versions here: https://www.nissanzclub.com/forum/threads/infotainment-software-version-table.2792/
Horso
Brandon
*Update*
After updating my updating my phone recently it seems to have fix the problem? Which is odd because It didn't do anything the last time there was an update and it was only on my Z that the issue occurred.
I appreciate everyone's comments/suggestions.
Horso
Brandon
And the issue is back 😩
_hz
Christian
DE
I don’t know if it’s actually being caused by this, but that behavior can occur when two things are connecting to the Bluetooth source at the same time. If you have any wireless headphones or other Bluetooth audio stuff, make sure you aren’t connected to those as well. There’s also an option in the car settings to allow multiple Bluetooth connections to the car at the same time. I would double check that setting and ensure it’s off. Not a guaranteed fix but it’s worth looking into.
