19" Watanabe Available for the Z
Running the 19X10.5 +25 wat wheel front and back. If they clear the brakes.
I want to see that 10.5 +25 fitment installed on the fronts compared to the spec'ed 9.5 +30, if any clearance issues with stock alignment, i.e. no crazy neg camber. If fits then would be an ideal square setup. The Wats are such a classic design, perfect for street setups although I would not track them.
I assume the 19” fit fine on a Sport if they fit the others. Anything to be aware of that isn’t obvious to wheel newbs like me?
Lug nut style. In a pic on another thread here they look to be acorn/tuner (conical) style. If so, the OEM lug nuts won't fit.
They will poke for sure a bit, they're 14.4 MM further out than they Z nismo stock wheel fitment which is pretty flush with the fender.
Also for reference; they will poke 27.7 mm more than the stock performance Z fitment. That's almost 3mm more poke than the Z1 25mm spacer kit for lowered cars, which definitely pokes in the front at stock ride height.
