Junkor
- Thread starter
- #1
So I have an 87 300z NA. We have done alot ov work to her. Wanted to do my first burnout and she did great. But the following morning. She would run rough, volt meter fluctuations between 8 and 15 volts would stabilize if I gave some throttle. But once moving lots ov hesitation and bogged down till I got it in 3rd gear. Now she fires up dropping in RPM till she stalls.
Checked codes TPS and a detonation code. We have checked for fuel pressure and exhaust both fine. Changed the fuel filter and got a new TPS. Figuring we will have to do a detonation sensor. But not sure where it is located I find alot on the z32.
So any thoughts on where it is and possibly other ideas that maybe causing this. And if it could be a wiring issue as well.
Thank you
Thank you
