Will it clear? Konig Hypergram
Neutr0n
Alberta
AW11, 3IS250, RZ34, ST185
I'm looking at the Konig Hypergram 19X10,5 +25mm for the front... will that width and offset cause any issue?
TIA
chadgigachad
Nismo OEM front wheels are 19x10 +33, I see no reason why your wheels wont fit. But use a calculator to be certain.
Inside would be fine. And shouldnt be a problem for brake clearance.
Outside might not. Not sure.
Lip would sit 27mm further out than the OEM Performance wheel.
Didn’t compare to OEM NISMO.
19x10.5 +25 lip (front fitment):
27mm further out than OEM Perormance wheel
14mm further out than OEM NISMO
Have extended studs and 10mm spacers but haven’t installed yet.
Interested to hear from those who’ve run wider wheels and/or 25mm spacers up front.
OptionZero
Norcal
2015 370Z Nismo
You need adjustable front arms to make those work in front
More camber is necessary
Who.Am.Eye.2716
The main concern would be if the Performance brakes will clear. The spokes on the Hypergram are flat face. You will need spacers to clear the brakes.
They will fit Sport brakes without spacers.
