Wheels for 2023+ Nismo Z
janejoh
Melbourne
Nismo Z
Hello all, can I use 19" wheels (like TSW, SSW, Niche, Konig, etc) on the 2023+ Nismo Z without additions like spacers? The front brake rotors are 380mm (15") and the calipers are huge. I'm concerned they'll be too large for the standard 19" wheels as the present 19" Rays are cutting it quite close. The rear should be fine to run 19" wheels without modifications though right? Also, what would be the minimum wheel and tire width and maximum tire aspect ratio I can run on front and rear for daily driving? I'm looking to reduce the width of my wheels and increase the aspect ratio/sidewall height for daily driving comfort and over pot holes without changing my suspension setup preferably. I don't really want to run 20" wheels for this reason.
Hernandooo
Hernan
Straya
2024 Nissan Z, Trek Bicycle
Will They FIt .com
I use this site to get a good idea of what specs would work with my car
Nissan OEM 19" Rims Specs. Front 19X9.5+40 , Rear 19x10+30
I found that for example, TE37 Saga S-Plus best fitment
Front 19x10.5+30, Rear 19x11+18. Poked the wheels out by 20 and 25mm, at the same time, maintaining clearance of suspension and brakes.
as for diameter, the smaller you go, the more likely you'll have to change out the oem rotors. so keep it at least 18" rims or greater
amp19
Chicagoland
2024 Nissan Z Sport
If I'm not looking to maximize performance with a staggered setup & using the stock suspension on a 2024 sport, fair to assume most 19x9.5 or 19x10 wheels will fit? Can we use the same offset front and rear or will that no longer fit/look right? Maybe a +35 but how can I tell?
