Suspension - Z proto vs 370Z
The Press Kit said they're using larger diameter shocks for front and back. It's said to improve handling over uneven surfaces.
Yep, per my talks with the Nissan rep, also diff spring rates, sway bars, susp geometry (not sure if mounting points changed but I'm sure camber caster settings). This is a good sign but we still don't know how extensive the actual testing is.
