Shift Knob Removal - No Damage
haohmaru
Gregory
New England
24 Z Perf / 13 WRX
Good news everyone, you can remove the shift knob without destroying it, with the right tools.
I used a large pair of channels locks, vice grips, a belt and a tshirt.
Honestly was not that difficult.
Leroy819
2024 Nissan Z - Yellow 6MT
Mechanic
What aftermarket knob are you putting on?
Did you have to heat up the loctite before removing it or just power through it?
haohmaru
haohmaru
Gregory
New England
24 Z Perf / 13 WRX
No I didn’t use any heat and I don’t think it was needed.
Knob: Billetworkz
Shifter: Stillen
Boot: @Customebrakes on Instagram
phil_chronicles
The method you used to remove the knob is what I am going to do.
Can you do a review on the Stillen? Not much info on Stillen in the Z. Does it shift smoother over stock, NVH increase at rpm ranges?
Thanks
Style point: If you would have flipped your channel locks OVER, when you push, you would be tightening the jaws, instead of relying on your grip strength.
haohmaru
haohmaru
Gregory
New England
24 Z Perf / 13 WRX
I uninstalled the Stillen shifter for the time being. The Billetworkz knob and boot retainer work fine on the OEM shifter and looks nearly identical to the stillen, just slightly taller. You just need to remove the spacer from the OEM shifter. See pic.
The worst part of this job is the linkage boot under car. You need some magic hands to get it back on.
haohmaru
haohmaru
Gregory
New England
24 Z Perf / 13 WRX
Thanks
The stillen shifter, at least the one I received, has a few bugs. Once I work them out with Will at Stillen, I’ll post a review.
Meg_Z
Oklahoma
Z Performance
Military
I just completed my shift knob replacement's it was a PITA. It does look like they used some type of loctite. I tried a belt wrench it didn’t budge it eventually I had to just use large channel locks. Even with OEM shifter covered up I damaged it. I used the bottom part of the OEM shifter and painted it gloss black to match Billetworkz knob.
haohmaru
haohmaru
Gregory
New England
24 Z Perf / 13 WRX
That looks great!
beergeek
Glen
RI
Could you elaborate on the issues you had with the Stillen shifter?
I’m looking at the Stillen or Z1.
haohmaru
haohmaru
Gregory
New England
24 Z Perf / 13 WRX
There’s a nylon cup that the ball of the shifter sits in, it should be loose and allow the shifter to move freely. The Stillen shifter was stiff and could barely move around in the cup. When it was installed, shifting required more force and the shifter wouldn’t snap back to center like normal. Everything was greased correctly, I swapped the OEM and stillen shifters a couple times to make sure.
Stillen said this wasn’t normal and they RMA’d it. I’m waiting to hear back if there was something wrong with it.
Supremekai
The stitching isn't centered..
