Noisy Boost Gauge Needle
Mud
Brisbane
I searched but couldn't find anything on this. Admin please delete/merge if there is already a thread
Is anyone having an issue with a noisy boost gauge needle.
Makes a plastic cogs whining/rubbing/grinding noise whenever the needle moves, which is obviously all the time.
Took me a while to track it down, as with normal road noise, radio, exhaust etc you cannot hear it.
95% of the time I don't hear it on start up either.
Just switching the car to on, without starting makes the needle sweep and demonstrates the noise, see video.
I the remember 370Z tacho and dials making similar sounds when turning the car on.
Anyway, I just raised it at my 3yr 30,000km dealer service and they've ordered a warranty replacement and quoted an hour to replace it (I really though this was a dash out job, but maybe they made the triple gauges easier to access than in the 370Z)
Well at least you got it figured out and got a replacement on the way. Good thing to look out for in case any of us have similar issues.
Forgive the obvious comment: You wore it out! Good on ya! 😉
Wild. I haven't had that issue. Nice that it'll be fixed under warranty. How long is the warranty in AU? If you're after the three-year mark in the US, you'd be paying for that yourself.
EarlsFat
Jim
2024 Z Performance, 1970 Camaro RS, 1953 Ford F100
CPA
Yep... sounds like a Geiger counter. Had that gauge replaced at 24,500.... and the idiots messed up the clock. I have to take it to a different dealership to get that fixed.
Mud
Mud
Brisbane
What clock?
EarlsFat
Jim
CPA
What clock?
The digital clock in the gauge pod... AND the main display if my phone isn't connected. ALWAYS starts at 6:18 every time I get in the car. If I adjust it to the correct time, it's 6:18 next time I start it up.
NOT happy with the dealership at all. They had adhesive all over the window when they fixed that gauge, fingerprints all over the place... "couldn't duplicate" a very clearly blown speaker, driver-side in the dash... do NOT go to Hertrich Nissan in Exton PA.
The resetting is odd, but not as odd to me as the fact that it starts at 6:18 every time.
Does it do it even when you quickly turn it off and back on, or does it have to be off for a little bit?
Typically a clock circuit resets to zero (midnight). Speculation, and no one cares anyway, but it's possible that 6:18PM, and maybe a specific date, was significant to whoever wrote that code and that's what they programmed in as the reset point.
Does the Z have a GPS time option? I'd scroll through the clock settings to make sure everything's set correctly.
